GigabitEthernet port status is UP and Protocol is Down.
jefferyj40
Is the subject line status correct? I have a gigabitethernet port (3845) that went from admin down, to reset and then status Down, protocol Down. Then I had another gigabitethernt port on a different 3845 router. To show port in status of UP and protocol Down, I didn't see a reset occur on this port. Which status is correct and does the reset step affect the final status being different?
JJ
8 Replies 8
jefferyj40
Also on both ports there is no ethernet cable!!
Ven Taylor
Level 4
Level 4
If you shut down the port, then reloaded without saving, the port will go back to a "no shut" state.
Did you write to memory?
Ven
Ven Taylor
I don't need it to be in a shut down state. I'm asking the question "what is the correct state for a ethernet port without a cable in it.  I see two different states for the same kind of port  UP/Down and Down/Down, also one of the ports went through a"reset" procces prior to Down/Down. Does this impact the process.
Down/Down is the normal state for a port with nothing in it.
Can you post the port config for the UP/Down port?
HTH, John *** Please rate all useful posts ***
interface GigabitEthernet0/1
description FastEthernet Connection to Cat6509-1 Port 3/40
ip address xxx.xxx.xxx.xxx 255.255.255.0
ip access-group 141 in
ip flow ingress
ip pim sparse-dense-mode
load-interval 30
duplex full
speed 100
media-type rj45
no mop enabled
service-policy input LAN-EDGE
Reading what you wrote the first time again...
I can think of two reasons why a switch interface would be up/down with no cable connected.
Port is configured as a routed port (no switchport)
Port is in monitor mode.
Check the port config and also check the global config for "monitor session" that references the switch port.
Ven
Ven Taylor
The device is a 3845 router, by default all ports will be routed or either a trunk uplink.
That looks like it makes sense then.
The port is configured, but not connected and/or administratively shut down.
By definition, it is up/down.
Ven
Ven Taylor
