How is my 2811 resolving DNS?
umbernaut
I do:
"ping google.com"
On my 2811 and it resolves and pings.
I do the same on my new 1811 and it gives:
"Translating "google.com"...domain server (255.255.255.255)
% Unrecognized host or address, or protocol not running."
So, I added to the 1811:
"ip name-server [public ip gateway]"
And can now resolve google.com on it too, but how is my 2811 resolving names?  I can find nothing in its config showing a name server or dns server entry.  Is there a show command that reveals a name server?
6 Replies 6
cadet alain
what does sh host command and sh run | i dns command output?
Alain.
#show host
Default domain is not set
Name/address lookup uses domain service
Name servers are 255.255.255.255
Codes: UN - unknown, EX - expired, OK - OK, ?? - revalidate
       temp - temporary, perm - permanent
       NA - Not Applicable None - Not defined
Host                      Port  Flags      Age Type   Address(es)
Edison Ortiz
Try show ip dns view
I don't see anything in this one or the last command that shows a DNS server entry:
#show ip dns view
DNS View default parameters:
Logging is off
DNS Resolver settings:
  Domain lookup is enabled
  Default domain name:
  Domain search list:
  Lookup timeout: 3 seconds
  Lookup retries: 2
  Domain name-servers:
DNS Server settings:
  Forwarding of queries is enabled
  Forwarder timeout: 3 seconds
  Forwarder retries: 2
  Forwarder addresses:
what does sh run | i dns says?
Alain.
"#sh run | i dns"
Outputs nothing just returns to a new prompt.
