GLBP help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-09-2015 06:39 AM - edited 03-05-2019 01:38 AM
Really confused on where I allocate an IP address from to use for GLBP interfaces on 2 core routers ?
here is the design
BGP router ( ISP )
Core router ____GLBP ______Core router
Layer 3 switch
Fire wall
Layer 3 switch ( access level , supporting VLANS ) subnet 126.89.120.0/27
any help would be appreciated
Aaron
- Labels:
Other Routing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-09-2015 11:10 PM
Feedback Forum is dedicated to other topics and you are off-topic here. See description for details.
This thread will be moved.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-10-2015 12:32 AM
Hello
So the redundent connection is between the Fw and the 2 rtrs?
Is your intention to supply resillience/load balancing for the wan connectivity ?
Do your L3 switch and frewall have the same default route pointing to the core rrtrs, or is the l3 switch pointing to the fw and the fw pointing to the core rtrs?
here is a example:
fa0/0 = link to bgp isp -
fa0/1 - link to fw - 1.1.1.0/24
core 1
track 2 interface FastEthernet0/0 line-protocol
track 1 interface FastEthernet0/1 line-protocol
ip address 1.1.1.2 255.255.255.0
duplex auto
speed auto
glbp 12 ip 1.1.1.254
glbp 12 priority 200
glbp 12 preempt
glbp 12 weighting 110 lower 95 upper 105
glbp 12 authentication text Stan
glbp 12 weighting track 1
glbp 12 weighting track 2
Core 2
ip address 1.1.1.3 255.255.255.0
duplex auto
speed auto
glbp 12 preempt
res
Paul
Kind Regards
Paul
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-10-2015 12:56 AM
Hi Paul
Thank you .
my intention is to provide load balancing and LAN redundancy between the two core routers in case one fails .
the two core routers are pointing to TWO seperate ISP's .
there is a layer 3 switch between the core router and the firewall , this was a business requirement . I can send a topology diagram to show what I mean .
i am just confused where I pull an IP address from to use on the GLBP interfaces and also a Virtual ip
does this help ?
i am really open to suggestions any help would be greatly appreciated
thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-10-2015 05:14 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
GLBP is unlikely to help you because it depends on multiple source MACs. If your traffic is coming from a FW (cluster), there's but one source MAC.
What you might be able to do is use mHSRP to have a virtual GW defined on both egress routers, and then route your FW traffic to each GW. This should then provide a "static" 50/50 outbound split.
In lieu of, or addition to, the foregoing, if your egress routers support PfR, it can do dynamic load balancing between them.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-10-2015 07:03 AM
hi
Then where do i implement HSRP ? at the core level between the two routers ?
how would the config look like ?
thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-10-2015 07:57 AM
Disclaimer
Posting
On the core router interfaces, facing the FW.
How - see http://www.cisco.com/c/en/us/support/docs/ip/hot-standby-router-protocol-hsrp/13781-7.html/index.html
