glbp help
aaronkb2002
my intention is to provide load balancing and LAN redundancy between the two core routers in case one fails .
the two core routers are pointing to TWO seperate ISP's .
there is a layer 3 switch between the core router and the firewall , this was a business requirement . I can send a topology diagram to show what I mean .
i am just confused where I pull an IP address from to use on the GLBP interfaces and also a Virtual ip
does this help ?
i am really open to suggestions any help would be greatly appreciated
- See more at: https://supportforums.cisco.com/discussion/12528726/glbp-help
Leo Laohoo
Duplicate thread.
Go HERE.
Leo Laohoo
Duplicate thread.
Go HERE.
Unfortunately no, the HERE itself is also duplicate. The primary thread is GLBP help
This thread will be moved to more appropriate forum because it's off-topic in Feedback Forum.
thank you
I appreciate your help
As you re-posted your's comment including the telepo_2.jpg attachment in primary thread, this thread is superfluous. Please consider to delete it. Thank you.
