GLBP with pix
sameh_hassan
sw---pix---Sw------R1--------ISP1
---pix--sw-------R2--------ISP2
i want to make load sharing between the two routers .
is GLBP is a suitable solution with pix and if it can how can i configure it (which virtual ip gateway that will be assigned by pix)
my network topology attached with my conversation
thx.
intelide3
hi,
are those L3 switches? can you just configure GLBP from there?
HTH.
ok i know ,but my problem how can i configure GLBP in case of the presence of pix ?
is the virtual ip address (virtual gateway) assigned to pix or lan users ???
