GLBP.
examples20001
Hi Experts,
I am testing the GLBP with two 1841, ios 12.4(3a) ADVSEC-K9-M image. The GLBP is configured at the LAN side interface (fa0/0) of both the router. I setup a pc with ip and gateway as vip of router.
Now I tried ping to my ISP router A.B.C.17 from the pc, it works fine.
Now I removed the link from the router and ping gave time out for so many mins. After some mins, the ping reply started.
I tested for so many times this and saw that the change over between the router is happening at different times (mins). Link 2 mins, 4 mins, 5 mins, 6 mins ....in different tests.
Is this a normal procedure, if so how to reduce the timing to a fast recovery of link?
I have attached the config details and GLBP details of both routers.
examples20001
After changing the weighting lower threshold value like below, the traffic change over between the routers takes only 45sec.
glbp 10 weighting 100 lower 95 <========= Added
http://www.cisco.com/en/US/products/ps6600/prod_presentation0900aecd801790a3.html
Test-A#
track 10 interface FastEthernet0/1 line-protocol
interface FastEthernet0/0
ip address 172.29.160.1 255.255.255.0
glbp 10 ip 172.29.160.3
glbp 10 timers redirect 120 720
glbp 10 preempt delay minimum 30
glbp 10 weighting track 10 decrement 10
Test-A#
Test-A#show track
Track 10
Interface FastEthernet0/1 line-protocol
Line protocol is Down (hw line state down)<==Change
24 changes, last change 00:02:14
Tracked by:
GLBP FastEthernet0/0 10
Test-A#
Test-A#show glbp
FastEthernet0/0 - Group 10
State is Active
5 state changes, last state change 07:17:50
Virtual IP address is 172.29.160.3
Hello time 3 sec, hold time 10 sec
Next hello sent in 1.288 secs
Redirect time 120 sec, forwarder time-out 720 sec
Preemption enabled, min delay 30 sec
Active is local
Standby is 172.29.160.2, priority 100 (expires in 9.024 sec)
Priority 100 (default)
Weighting 90, low (configured 100), thresholds: lower 95, upper 100 <============== Changed
Track object 10 state Down decrement 10
Load balancing: round-robin
Group members:
0015.f975.cdce (172.29.160.2)
0015.f975.f166 (172.29.160.1) local
There are 2 forwarders (0 active)
Forwarder 1
State is Listen
10 state changes, last state change 00:01:35
MAC address is 0007.b400.0a01 (default)
Owner ID is 0015.f975.f166
Redirection enabled
Active is 172.29.160.2 (secondary), weighting 100 (expires in 7.584 sec)
Arp replies sent: 13
Forwarder 2
State is Listen
4 state changes, last state change 00:12:33
MAC address is 0007.b400.0a02 (learnt)
Owner ID is 0015.f975.cdce
Redirection enabled, 117.584 sec remaining (maximum 120 sec)
Time to live: 717.584 sec (maximum 720 sec)
Active is 172.29.160.2 (primary), weighting 100 (expires in 7.584 sec)
Arp replies sent: 1
Test-A#
Hi All,
After doing some fine tunning, the change over between routers takes between 1sec to 8sec in different tests.
Below is the setup details.
Thank you very much.
http://www.cisco.com/warp/public/732/Tech/ipservices/docs/glbp.pdf
Test-A#
glbp 10 preempt <============================changed
glbp 10 forwarder preempt delay minimum 0 <=========== Added
Test-A#
Test-A#show glbp
State is Active
5 state changes, last state change 1d01h
Next hello sent in 0.272 secs
Preemption enabled, min delay 0 sec <=======================changed
Active is local
Standby is 172.29.160.2, priority 100 (expires in 8.580 sec)
Weighting 100 (configured 100), thresholds: lower 95, upper 100
Track object 10 state Up decrement 10
Group members:
There are 2 forwarders (1 active)
Forwarder 1
State is Active
21 state changes, last state change 00:19:14
Redirection enabled
Preemption enabled, min delay 0 sec <====================changed
Active is local, weighting 100
Arp replies sent: 22
Forwarder 2
State is Listen
18 state changes, last state change 00:03:07
Redirection enabled, 117.048 sec remaining (maximum 120 sec)
Time to live: 717.048 sec (maximum 720 sec)
Active is 172.29.160.2 (primary), weighting 100 (expires in 7.048 sec)
Arp replies sent: 11
Test-A#
Test-A#show glbp brief
Interface Grp Fwd Pri State Address Active router Standby route
Fa0/0 10 - 100 Active 172.29.160.3 local 172.29.160.2
Fa0/0 10 1 7 Active 0007.b400.0a01 local -
Fa0/0 10 2 7 Listen 0007.b400.0a02 172.29.160.2 -
Test-A#
Test-A#show track
Track 10
Line protocol is Up
33 changes, last change 00:19:44
Tracked by:
Test-A#
