Global Route to VRF
Andrew Clark
Hello. I'm having an issue with routing when it comes to a non-vrf to vrf.
on router1 i can ping and traceroute using the VRF with no problems to the destination subnet.
on router2 it will forward the traffic to router 1 but then just dies there.
router1 P2P to WAN 192.168.39.40/29
router2 to router1 10.0.251.0/24
remote site 10.19.4/24
router 1
interface port-channel1.903
encapsulation dot1q 903
ip vrf forwarding public-captive
ip address 10.0.251.253 255.255.255.0
interface port-channel1.78
encapsulation dot1q 78
ip address 192.168.39.42 255.255.255.248
ip route vrf public-captive 0.0.0.0 0.0.0.0 10.0.251.254
ip route vrf public-captive 10.19.4.0 255.255.255.0 192.168.39.41
router 2
interface gig0/0.903
ip address 10.0.251.254 255.255.255.0
ip route 10.0.0.0 255.128.0.0 10.0.251.253
Hello
On router 1 you need to tell the global rib how to get to 10.0.251.253/24 as that address resides in a vrf table of which the global riib is unaware.
Apply a static route pointing to the physical interface and test again
Also do you really require pc 1.78 in any vrf as that is facing rtr2
If remove that from the vrf you could just have one vrf default static and one global rib static.
Router 1
No ip route vrf public-captive 0.0.0.0 0.0.0.0 10.0.251.254
No ip route vrf public-captive 10.19.4.0 255.255.255.0 192.168.39.41
ip route 10.0.251.0 255.255.255.0 port-channel1.903
Ip route 0.0.0.0 0.0.0.0 192.168.39.41
ip route vrf public-captive 0.0.0.0 0.0.0.0 192.168.39.41 global
Kind Regards
Paul
