GLOBAL VRF ROUTE LEAKING
Babak40
Hi Guys ,
In our core router we have 20 VRFs and by using static route all traffic goes to ISP1 .
Our router is Peered with a Carried Neutral (we name it XX)  as well to make web browsing faster.
The problem is at the moment my global routing table has 60000 bgp routes which has received from XX
and if I want to inject them to each VRF ,it uses 20*60000 route entries which kills the memory
How can I share global BGP table with Vrfs and send some traffics to XX ?
9 Replies 9
Nagendra Kumar Nainar
For each of those 20 VRFs, are you using a static default route?. If so, I think you can configure another vrf specific default static route with NH from global.
Below is an example:
ip route vrf TEST 0.0.0.0 0.0.0.0 10.1.23.3
ip route vrf TEST 0.0.0.0 0.0.0.0 10.1.25.5 global
The above will install 2 default static routes in VRF TEST table with 1 NH as 10.1.23.3 from VRF TEST and other NH 10.1.25.5 from global routing table.
Below is the CEF output:
R2#sh ip cef vrf TEST 0.0.0.0/0 detail
0.0.0.0/0, epoch 0, flags [default route], per-destination sharing
recursive via 10.1.23.3
recursive via 10.1.23.0/24
attached to Ethernet0/0.2
recursive via 10.1.25.5
recursive via 10.1.25.0/24
attached to Ethernet0/0.25
R2#
HTH,
Nagendra
Hello
just like to add you will need to tell the global rib how to each your vrfs  so you’ll need a static route stating the vrf subnet and point it towards the vrf interface
Kind Regards
Paul
Yes right, for the return traffic from XX to hosts in VRF. Thanks for pointing
Hi Paul,
I replied in the group please have a look .thanks
Hi Nagendra ,
The problem is one of them is ISP the other one is not ISP it''s carrier
Neutral it means we can reach to half of our destination through this
carrier faster ,but not all destination.
It means if I put my default route to this carrier half of them will be
dropped .
This carrier has redistributed 60000 routes to bgp and those routed are
most for Facebook,Google,....
So if I go to Facebook from my ISP it takes 10 hops to reach the
destination but using carried takes 5 hops
One solution that comes to my mind is redistribute those bgp routes to my
vrfs but imagine 20*60000 routes ...router will die
Is there any idea ?
Hello
so would like to push certain vrf internal traffic via the carrier fast path?
Kind Regards
Paul
Yes Exactly ,I want to push some VRF's to use the carrier for half of their traffic and ISP for the rest of traffic
Is there any way to share the bgp table of the router to vrfs without redistribute whole routes to vrfs
Hello
sounds like policy based routing would be applicable however depending on how your topology is connected you could manipulate traffic flow via bgp/igp route manipulation
can you shate a topology
Kind Regards
Paul
rais
Level 7
Level 7
How about asking ISP1 for BGP and pointing default route to XX.
HTH.
