IPSEC Tunnel Fails 2x2921 - Please Help
I tried putting a routing statement but no change.  NO PRIVATE INFO: I'll change the crypto key once I get this working.
ip route 192.168.175.0 255.255.255.0 192.168.176.1
ip route 192.168.176.0 255.255.255.0 192.168.175.1
!!!@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ SITE 1 @@@@@@@@@@@@@@@@@@@@@@@@!!!!
localrtr#sh run
hostname localrtr
boot-start-marker
boot-end-marker
enable secret 5 $1$A3Kg$TZeqZI6QF3r.S4nu80fZJ1
no aaa new-model
ip domain name mydomain.com
ip cef
username cisco privilege 0 password 7 05190900355E41060D
crypto isakmp policy 1
 encr 3des
 hash md5
 authentication pre-share
 group 2
crypto isakmp key firewallcx address 192.168.168.236
crypto ipsec transform-set TS esp-3des esp-md5-hmac
crypto map CMAP 10 ipsec-isakmp
 set peer 192.168.168.236
 set transform-set TS
 match address VPN_TRAFFIC
interface GigabitEthernet0/0
 description OUTSIDE
 ip address 192.168.168.235 255.255.255.0
 duplex auto
 speed auto
 crypto map CMAP
interface GigabitEthernet0/1
 description INSIDE
 ip address 192.168.175.1 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 duplex auto
 speed auto
interface FastEthernet0/0/0
 description MGNT_10_10_10_15
 switchport access vlan 200
 no ip address
interface Vlan200
 ip address 10.10.10.15 255.255.255.224
ip access-list extended VPN_TRAFFIC
 permit ip 192.168.175.0 0.0.0.255 192.168.176.0 0.0.0.255
control-plane
line con 0
line vty 0 4
 login local
 transport input ssh
end
localrtr#ping 192.168.176.1 so gi0/1
Sending 5, 100-byte ICMP Echos to 192.168.176.1, timeout is 2 seconds:
Packet sent with a source address of 192.168.175.1
Success rate is 0 percent (0/5)
localrtr#
localrtr#ping 192.168.168.236
Sending 5, 100-byte ICMP Echos to 192.168.168.236, timeout is 2 seconds:
Success rate is 80 percent (4/5), round-trip min/avg/max = 1/1/1 ms
localrtr#
localrtr# debug crypto cond peer ipv4 192.168.176.1
localrtr# debug crypto ipsec
localrtr# debug crypto isakmp
localrtr# term mon
localrtr# sh cry isa pol
Global IKE policy
Protection suite of priority 1
    encryption algorithm:    Three key triple DES
    hash algorithm:        Message Digest 5
    authentication method:    Pre-Shared Key
    Diffie-Hellman group:    #2 (1024 bit)
    lifetime:        86400 seconds, no volume limit
localrtr#
localrtr#sh crypto map
Crypto Map IPv4 "CMAP" 10 ipsec-isakmp
    Peer = 192.168.168.236
    Extended IP access list VPN_TRAFFIC
        access-list VPN_TRAFFIC permit ip 192.168.175.0 0.0.0.255 192.168.176.0 0.0.0.255
    Current peer: 192.168.168.236
    Security association lifetime: 4608000 kilobytes/3600 seconds
    Responder-Only (Y/N): N
    PFS (Y/N): N
    Transform sets={
        TS:  { esp-3des esp-md5-hmac  } ,
    Interfaces using crypto map CMAP:
        GigabitEthernet0/0
localrtr#
localrtr#sh crypto session
Crypto session current status
Interface: GigabitEthernet0/0
Session status: DOWN
Peer: 192.168.168.236 port 500 localrtr#sh crypto session
  IPSEC FLOW: permit ip 192.168.175.0/255.255.255.0 192.168.176.0/255.255.255.0
        Active SAs: 0, origin: crypto map
localrtr#
Dec 14 17:43:46.005: No peer struct to get peer description
localrtr#
!!!@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ SITE 2 @@@@@@@@@@@@@@@@@@@@@@@@@!!!!
remotertr#sh run
hostname remotertr
boot-start-marker
boot-end-marker
enable secret 5 $1$m3qS$tiNd8YH.rmhKzGoRqa2970
no aaa new-model
username cisco privilege 0 password 7 105C061611051D0418
 encr 3des
 hash md5
 group 2
crypto isakmp key firewallcx address 192.168.168.235
 mode tunnel
 set peer 192.168.168.235
 description OUTSIDE
 ip address 192.168.168.236 255.255.255.0
 duplex auto
 speed auto
 crypto map CMAP
 description INSIDE
 ip address 192.168.176.1 255.255.255.0
 duplex auto
 speed auto
 description MNGT
 ip address 10.10.10.16 255.255.255.224
 duplex auto
 speed auto
 permit ip 192.168.176.0 0.0.0.255 192.168.175.0 0.0.0.255
control-plane
line con 0
line vty 0 4
 login local
 transport input ssh
end
remotertr#ping 192.168.175.1 so gi0/1
Sending 5, 100-byte ICMP Echos to 192.168.175.1, timeout is 2 seconds:
Packet sent with a source address of 192.168.176.1
remotertr#
remotertr#ping 192.168.168.235
Sending 5, 100-byte ICMP Echos to 192.168.168.235, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
remotertr#
remotertr#debug crypto cond peer ipv4 192.168.175.1
remotertr#debug crypto ipsec
remotertr#debug crypto isakmp
remotertr#term mon
remotertr#sh cry isa pol
Global IKE policy
remotertr#
remotertr#sh crypto map
    Peer = 192.168.168.235
        access-list VPN_TRAFFIC permit ip 192.168.176.0 0.0.0.255 192.168.175.0 0.0.0.255
    Current peer: 192.168.168.235
    PFS (Y/N): N
    Mixed-mode : Disabled
    Transform sets={
        GigabitEthernet0/0
    Interfaces using crypto map NiStTeSt1:
remotertr#
    PFS (Y/N): N
    Transform sets={
        GigabitEthernet0/0
remotertr#
remotertr#sh crypto session
Peer: 192.168.168.235 port 500
  IPSEC FLOW: permit ip 192.168.176.0/255.255.255.0 192.168.175.0/255.255.255.0
remotertr#
*Dec 14 17:18:13.423: No peer struct to get peer description
remotertr#
I have re-read this thread several times and have some additional comments/questions.
I see this in some output from router 2
I do not see any reference to that crypto map in the configs and assume that it was perhaps in an earlier version of the config and has been removed. I would suggest reboot of both routers to remove any lingering memory of things that have been removed from the configs.
I noticed that when you were setting up conditional debug (which is a VERY helpful tool when troubleshooting vpn) that the address you specified (which should be the peer address) was the address of the peer lan - but not the peer address (192.168.168.235/236). If you clean that up done know if debug would have helpful information.
I do not see any route statements in the configs that you posted. And in one post you suggest that the tunnels act like routing statements and so you do not need route statements. That is not the case. To clarify the issue would you post the output of show ip route from both routers?
Rick
Rick
28 Replies 28
chrihussey
Think your static routes are incorrect. Try:
ip route 192.168.175.0 255.255.255.0 192.168.168.236
ip route 192.168.176.0 255.255.255.0 192.168.168.235
The tunnel is up but I don't know how to use it?  Why can't I ping the inside addresses?
localrtr(config)#no ip access-list extended VPN_TRAFFIC
localrtr(config)#ip access-list extended VPN_TRAFFIC
localrtr(config-ext-nacl)# permit ip any any
localrtr(config-ext-nacl)#end
localrtr#sh cry ses
Session status: UP-ACTIVE
IKEv1 SA: local 192.168.168.235/500 remote 192.168.168.236/500 Active
IPSEC FLOW: permit ip 0.0.0.0/0.0.0.0 0.0.0.0/0.0.0.0
Active SAs: 2, origin: crypto map
localrtr#
remotertr(config)#no ip access-list extended VPN_TRAFFIC
remotertr(config)#ip access-list extended VPN_TRAFFIC
remotertr(config-ext-nacl)# permit ip any any
remotertr(config-ext-nacl)#end
remotertr#sh cry ses
Session ID: 0
IKEv1 SA: local 192.168.168.236/500 remote 192.168.168.235/500 Active
remotertr#
Do a source ping.....
ping
Protocol [ip]:
Target IP address: 192.168.176.1
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Ingress ping [n]:
Source address or interface: 192.168.175.1
localrtr#ping 192.168.176.1 so 192.168.175.1
localrtr#
 localrtr#sh ip int br
Embedded-Service-Engine0/0 unassigned YES unset administratively down down
GigabitEthernet0/0 192.168.168.235 YES manual up up
GigabitEthernet0/1 192.168.175.1 YES manual up up
Thanks for your reply,
I put the route in but I still can't ping the inside network....  There are matches on the ACL now that it's changed to any any.... Should the ACL also include R1 inside to R2 outside?
localrtr#sh run | i route
localrtr#sh ip access-lists
10 permit ip any any (156 matches)
localrtr#
remotertr#sh run | i route
remotertr#sh ip access-lists
10 permit ip any any (255 matches)
remotertr#
At least the L3 tunnel is up.  I don't know why the original ACL stopped isakmp from reaching the peer?   Should it look like this?
localrtr#
permit ip 192.168.175.0 0.0.0.255 host 192.168.236.1
permit ip host 192.168.235.1 host 192.168.236.1
No, the way you had the ACL originally was correct.
Do you still have the statics I suggested and did the source ping?
Are all interfaces up/up?
Think I found the issue, you're missing "mode tunnel" on the localrtr:
 mode tunnel
Also could try a VTI and set static routes to send traffic down interface.
I think that "mode tunnel" is the default, see the following.  The tunnel still crashes when I put in the correct "match addess"???
I also think that an IPSEC tunnel acts like a routing statement and I don't need an IP ROUTE command.
MODE-TUNNEL___MODE-TUNNEL___MODE-TUNNEL___MODE-TUNNEL___MODE-TUNNEL___MODE-TUNNEL___
localrtr#sh run all | b crypto ipsec transform-set
crypto ipsec transform-set default esp-aes esp-sha-hmac
mode tunnel
mode tunnel
crypto ipsec nat-transparency udp-encapsulation
crypto ipsec profile default
remotertr#sh run all | b crypto ipsec transform-set
mode transport
mode tunnel
---------------------INT UP___INT UP___INT UP___INT UP___INT UP------------------------------
localrtr#ping 192.168.175.1
localrtr#ping 192.168.168.235
localrtr#
remotertr#sh ip int br
GigabitEthernet0/0 192.168.168.236 YES manual up up
GigabitEthernet0/1 192.168.176.1 YES manual up up
remotertr#ping 192.168.168.236
remotertr#ping 192.168.176.1
remotertr#
I am confused about what does work or what does not work. Can you clarify?
And I am confused about the purpose in posting the sections showing interface up and pinging local interfaces. It would be much more instructive to show results of ping to remote addresses.
Rick
Rick
I've pinned it down to the distant end.  It just doesn't see the inside network on the other end.  Note the so (source) in the ping statement.
IPSEC FLOW: permit ip 192.168.175.0/255.255.255.0 0.0.0.0/0.0.0.0
localrtr#
------------------=====ACL Increments matches============-----------------
3 permit ip 192.168.175.0 0.0.0.255 any (116 matches)
localrtr#ping 192.168.186.1 so 192.168.175.1
3 permit ip 192.168.175.0 0.0.0.255 any (132 matches)
It looks like your acl for encryption uses any in its permit
Cisco advises to not use any in the permit for encryption. Please change the acl and permit the remote subnet.
It might be helpful if you post the output of show crypto ipsec sa
Rick
Rick
I just took a second look at what you posted and noticed this mismatch
Rick
Rick
