gns
Hi everybody,
When I wanna use my routers I face this error: Could not start dynamips: [win error 193] %1 is not a valid Win32  application.
Thanks for your assist in advance
try and deinstall GNS3 (all version of you have previous ones installed), disable any antivirus software as well as the Windows firewall, and reinstall GNS3.
Martin L
in old days, I had that error few times; but not in new gns3 2.x
Make sure you run dynamips as admin; got to program folder and right click on dynamips.exe , select run as administrator.
also check your firewall-anti-virus software.
Regards, ML
**Please Rate All Helpful Responses **
