got a lot of ip address 0.0.0.0 from command "show cable host access-group"
mishao
hi,
i issued command " show cable host access-group" at ubr 10012 and found a lot of cpe with ip address 0.0.0.0. i use the command( clear cable host xxx) to remove 0.0.0.0 entry. But dose anyone know the reason why ? how to remove it more efficiency ?
best regards.
fred.
uBR-10K#show cable host access-group
0016.cbf6.1e7f 0.0.0.0 host
0017.4239.655a 0.0.0.0 host
00e0.0609.0038 219.71.203.210 host
0002.8adf.de7c 0.0.0.0 host
000c.6e64.a4f9 0.0.0.0 host
0030.0403.fd5d 219.71.219.37 host
0090.0b04.2ae2 219.71.244.66 host
0000.0100.5adc 219.71.245.160 host
0009.2ded.d4b7 0.0.0.0 host
000a.7998.591d 0.0.0.0 host
000d.60e4.b091 0.0.0.0 host
0013.0220.3ff7 0.0.0.0 host
0016.4116.9ff1 0.0.0.0 host
0016.ec55.5776 0.0.0.0 host
0018.f35a.8b03 0.0.0.0 host
purohit_810
Level 5
Level 5
I think it shows you default route address.
But you can do one thing, by using Sniffer you can check out MAC addesss -> IP address.
Dharmesh Purohit
purohit_810
Level 5
Level 5
0.0.0.0 is belongs to source IP address.
Source IP address for the DSG stream. If an asterisk (*) appears as the source IP address, it indicates that the source IP address is 0.0.0.0, which allows any IP address as the source IP address.
http://www.cisco.com/en/US/products/hw/cable/ps2217/products_command_reference_chapter09186a008018981c.html#wp1169868
Dharmesh Purohit
