Got errors when uploading IOS via xmodem in my 3660 router
darksilver26
rommon 6 > xmodem -c c3660-i-mz.122-40a.bin
Do not start the sending program yet...
         File size           Checksum   File name
   6371604 bytes (0x613914)   0x2d8d    c3660-i-mz.122-26.bin (bad checksum: 0xb195)
WARNING: All existing data in flash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n  [n]:  y
Ready to receive file c3660-i-mz.122-40a.bin ...
Erasing flash at 0x30fc0000Erasing flash at 0x30d40000
program flash location 0x30610000
Download Complete!
*** GT64120 Master Abort Interrupt ***
PC = 0x80005624, Cause = 0x4000, Status Reg = 0x3041f003
monitor: command "xmodem" aborted due to exception
rommon 7 > set
PS1=rommon ! >
CRASHINFO=flash:crashinfo_19930301-001901
RET_2_RTS=
BSI=0
RET_2_RCALTS=
?=1
rommon 8 >
what's wrong with my 3660 router? i already changed my flash memory still the same..
Leo Laohoo
File is corrupt.
how would i clean up my flash memory to delete the existing IOS? so that this error won't appear?
rommon 2 > meminfo
Main memory size: 256 MB in 64 bit mode.
Available main memory starts at 0xa000e000, size 262088KB
IO (packet) memory size: 0 percent of main memory.
NVRAM size: 128KB
rommon 3 > set
PS1=rommon ! >
RET_2_RTS=
BSI=0
RET_2_RCALTS=
?=0
rommon 4 >
Check your memory using the command "dir flash<0 or 1>:".  If the file(s) there then erase using the command "delete flash<0 or 1>:".  If  it's a directory, then you'll need to go into that directory and use the same command to delete a file.
Besides the crashinfo file is the least of your worries.  The issue you have is your IOS you're uploading is corrup.  You need to re-download the IOS from the Cisco Download Centre and check/verify that the MD5 checksum is correct before transfering the IOS to the router.
rommon 9 > ?
alias               set and display aliases command
boot                boot up an external process
break               set/show/clear the breakpoint
confreg             configuration register utility
cont                continue executing a downloaded image
context             display the context of a loaded image
cookie              display contents of motherboard cookie PROM in hex
dev                 list the device table
dir                 list files in file system
dis                 disassemble instruction stream
dnld                serial download a program module
frame               print out a selected stack frame
help                monitor builtin command help
history             monitor command history
iomemdef            set IO mem to a default 25%
meminfo             main memory information
repeat              repeat a monitor command
reset               system reset
set                 display the monitor variables
stack               produce a stack trace
sync                write monitor environment to NVRAM
sysret              print out info from last system return
unalias             unset an alias
unset               unset a monitor variable
xmodem              x/ymodem image download
rommon 10 > set
PS1=rommon ! >
RET_2_RTS=
BSI=0
RET_2_RCALTS=
?=0
rommon 11 > dir flash0:
bad device name
usage: dir
rommon 12 > dir flash:
   6376124 bytes (0x614abc)   0x1e31    c3660-i-mz.122-40a.bin (bad checksum: 0x31df)
rommon 13 > delete flash: c3660-i-mz.122-40a.bin
monitor: command "delete" not found
rommon 14 >
Those are the available commands. delete function is not found... ok... i guess i have to download a new IOS
