GRE issue ; Tunnel up/down on one side and up/up on the other side
adrienbomble
Hello Gents,
We have an issue with a very basic GRE configuration ; GRE Tunnel is up/up on one side but up/down on the other side.
It's possible to ping tunnel destination from each side, but the tunnel doesn't come up.
Here are router configs :
R1 (Cisco 3945E Version 15.2(4)M4)
interface Loopback3
ip address 10.10.112.97 255.255.255.252
interface Tunnel50
ip address 192.168.255.234 255.255.255.252
tunnel source Loopback3
tunnel destination 10.10.108.57
R1#ping 10.10.108.57 source loopback 3
Sending 5, 100-byte ICMP Echos to 10.10.108.57, timeout is 2 seconds:
Packet sent with a source address of 10.10.112.97
Success rate is 100 percent (5/5), round-trip min/avg/max = 96/110/168 ms
R1#sh int tunnel 50
Tunnel50 is up, line protocol is down
  Hardware is Tunnel
  Internet address is 192.168.255.234/30
  MTU 17916 bytes, BW 100 Kbit/sec, DLY 50000 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 10.10.112.97 (Loopback3), destination 10.10.108.57
   Tunnel Subblocks:
      src-track:
         Tunnel50 source tracking subblock associated with Loopback3
          Set of tunnels with source Loopback3, 3 members (includes iterators), on interface <OK>
  Tunnel protocol/transport GRE/IP
    Key disabled, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255, Fast tunneling enabled
  Path MTU Discovery, ager 10 mins, min MTU 92
  Tunnel transport MTU 1476 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Last input 00:01:23, output 00:01:37, output hang never
  Last clearing of "show interface" counters 02:00:10
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
     360 packets input, 21764 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     298 packets output, 14304 bytes, 0 underruns
     0 unknown protocol drops
R2 (Cisco 3745 Version 12.4(7))
interface Loopback1
ip address 10.10.108.57 255.255.255.255
end
interface Tunnel50
ip address 192.168.255.233 255.255.255.252
tunnel source Loopback1
tunnel destination 10.10.112.97
R2#ping 10.10.112.97 source loopback 1
Sending 5, 100-byte ICMP Echos to 10.10.112.97, timeout is 2 seconds:
Packet sent with a source address of 10.10.108.57
Success rate is 100 percent (5/5), round-trip min/avg/max = 92/96/104 ms
R2#sh int tunnel 50
Tunnel50 is up, line protocol is up
  Hardware is Tunnel
  Internet address is 192.168.255.233/30
  MTU 1514 bytes, BW 9 Kbit, DLY 500000 usec,
  Keepalive not set
  Tunnel source 10.10.108.57 (Loopback1), destination 10.10.112.97
  Tunnel TTL 255
  Last input 00:16:02, output 00:04:58, output hang never
  Last clearing of "show interface" counters 00:32:16
     298 packets input, 14304 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     301 packets output, 14448 bytes, 0 underruns
For information, routing is all static.
I tried to activate keepalive and i can see that they are correctly received on each side but tunnel on R1 was still line protocol down; so i removed it.
Jan 15 17:32:28: Tunnel50: sending keepalive, 10.10.112.97->10.10.108.57 (len=24 ttl=255), counter=1
Jan 15 17:32:28: Tunnel50: keepalive received, 10.10.112.97->10.10.108.57 (len=24 ttl=244), resetting counter
I have also checked on bug tool search but i couldn't find any bug related to our issue.
If you add any advice, it will be very appreciated ; ) !
Best Regards,
Adrien
Hello
Tunnel MTU values are different, On Each tunnel
Int tun xxx
ip tcp-adjust mss 1476
Res
Paul
Kind Regards
Paul
