GRE tunnel flapping
scottshaw2
Trying to create a GRE tunnel between two routers that cross another network.
I have the following configs on the routers, I can ping across the tunnel, everything seems to work until I try adding ospf.
then I  the following error: FULL to DOWN, Neighbor Down: Interface down or detached
rtr config.GIFGRE tunnel, Routing Protocols,
30 Replies 30
yes I'm seeing the error on both routers.
Sorry missed this and didn't look at the log while at work, will see if I can find anything interesting in it
I did " debug ip ospf hello and packet, I was seeing send and receive hello's on both routers.
I didn't see any error on the packets.
In my R1 log I’m getting:
I noticed on the original IP list R2 LB is incorrect should be 0.2/32
OSPF-5-ADJCHG NBR 0.2 Loading to Full, loading done
OSPF-5-ADJCHG NBR 0.2Full to Down, neighbor down: interface down or detached
C4K_Switchingengineman-4-vfeopinterrupt:standby:vfe op rrqenqcntexceed inerrupt
Router 1 is a pair of 4500X set up in VSS
Hi Scott,
Can you try modifying the static routes for the tunnel destination on both RTR-1 and RTR-2 as follow and see if it makes a difference.
RTR-1:
ip route 10.1.5.14 255.255.255.255 Ten1/2/16 10.1.5.9
RTR-2:
ip route 10.1.5.10 255.255.255.255 Ten1/2/32 10.1.5.13
the 5.9 and 5.13 are direct connected encryption devices.
Was there a link to the document?
Will I need to enable multicast routing?
Apart from including the tunnel interface IP address in the router ospf network statement, there is nothing special that needs to be configured to run ospf over the tunnel interfaces.
Hello
Stop the redistribution of all your static routes to negate recursive routing and as stated the next hop ip addressing  of your default static routes are the same which is incorrect
Kind Regards
Paul
Tried on router 1 still seeing the error, cant on router 2, it has a bunch of static routes.
Hello @scottshaw2 ,
you can use a route-map on R2 to avoid redistribution of the static route for the tunnel destination and you can then still redistribute all the other static routes.
ip prefix-list TUN-DEST permit 10.1.5.10/32
route-map STATIC-INTO-OSPF deny 10
match address prefix TUN-DEST
route-map STATIC-INTO-OSPF permit 20
router ospf 1
redistribute static subnets type 1 route-map STATIC-INTO-OSPF
Hope to help
Giuseppe
Hi friend I make deep view and I think I found issue here,
this is IP and subnet you use as your original post.
IN R1 there must be two important prefix
S 10.1.5.14 255.255.255.255 10.1.5.9 <- that OK if the 10.1.5.9 is direct connect BUT
as you see 10.1.5.10/30 subnet there is 10.1.5.9 ip address this this subnet pool!!!!
also
this show ip route in R1,
if the R2 redistribute the route into OSPF and R1 learn this route from R2 via tunnel OSPF then there must two
S 10.1.5.14 255.255.255.255 via 10.1.5.9
O 10.1.5.8/30  via 10.1.1.2 tunnel "because the R2 have this static route toward R1 for tunnel destination"
But It have 10.1.5.12/30 which mean that R2 have S route toward 10.1.5.12 not toward 10.1.5.8, and for the tunnel how it UP because it use the default route not this wrong static route.
Not sure I'm following what you are saying.
R2 has a static 10.1.5.10 255.255.255.255 10.1.5.13
the .9 and .13 are direct connected crypto devices.
I cant find the post, but someone mentioned adding a "tunnel key xx" to the tunnel configuration.
when I use the command I get a warning saying " feature not supported in hardware. packets will be software switched"
however using this command seams to be the solution, I'm going to assume its something unique to the 4500X, since I have tunnels configure the same way running between 6509's that don't have the "tunnel key xx".
thanks for everyone's thoughts and assistance.
