GRE Tunnel issue
lmanavalan
On a Cisco 7301 i have configured GRE Tunnel with vrf mgnt and the Tunnel source interface is not part of any vrf.
The other end of the Tunnel is simple GRE configuration with out any vrf.
The tunnel is not coming up.
Below is the configuration
Router_2:
hostname Router_2
vrf definition mgmt
 description VRF for Management
 rd 1000:1000
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
crypto isakmp policy 10
 encr aes
 authentication pre-share
 group 2
crypto isakmp key <removed> address 122.x.x.66
crypto ipsec transform-set aes-128-sha esp-aes esp-sha-hmac
 mode tunnel
crypto map managementVpn 10 ipsec-isakmp
 set peer 122.x.58.x
 set transform-set aes-128-sha
 match address VpnList
interface Tunnel1
 vrf forwarding mgmt
 ip address 10.157.252.78 255.255.255.252
 ip tcp adjust-mss 1200
 ip ospf 2 area 0
 keepalive 1 3
 tunnel source 162.249.176.141
 tunnel destination 10.176.21.6
 tunnel vrf mgmt
interface GigabitEthernet0/0
 no ip address
 media-type rj45
 speed auto
 duplex auto
 negotiation auto
interface GigabitEthernet0/0.101
 encapsulation dot1Q 101
 ip address 162.x.x.141 255.255.255.248
 standby 101 ip 162.x.x.142
interface GigabitEthernet0/1
 no ip address
 media-type rj45
 speed auto
 duplex auto
 negotiation auto
interface GigabitEthernet0/1.102
 encapsulation dot1Q 102
 ip address 10.177.56.19 255.255.255.248
 standby 102 ip 10.177.56.17
interface GigabitEthernet0/1.108
 description Link to MgmtVlan
 encapsulation dot1Q 108
 vrf forwarding mgmt
 ip address 10.157.64.131 255.255.255.128
 standby 108 ip 10.157.64.129
interface GigabitEthernet0/2
 no ip address
 shutdown
 media-type rj45
 speed auto
 duplex auto
 negotiation auto
router ospf 2 vrf mgmt
 router-id 10.157.64.4
 network 10.157.64.0 0.0.3.255 area 100
router ospf 1
 router-id 10.177.56.2
 network 10.177.56.0 0.0.3.255 area 0
ip route 0.0.0.0 0.0.0.0 162.x.x.137
ip route 10.176.21.6 255.255.255.255 162.x.x.137
ip access-list extended VpnList
 permit ip host 162.x.x.141 host 10.176.21.6
And Router_1 Confuuguration:
interface Tunnel 101
 ip address 10.157.252.77 255.255.255.252
 ip ospf 1 area 0
 keepalive 1 3
 tunnel source 10.176.21.6
 tunnel destination 162.x.x.141
regards
Logesh
Hello Imanavalan,
Please note that there is a difference between the commands "vrf forwarding mgmt" and the command "tunnel vrf mgmt".
At first when you used the "tunnel vrf mgmt" the router looked for the tunnel source IP and tunnel destination IP in the vrf mgmt, the tunnel source "162.249.176.141" is configured under the interface GigabitEthernet0/0.101 which does not belong to vrf mgmt, and the tunnel destination "10.176.21.6" is under the global routing table by means of a static route and again it does not belong to the vrf mgmt. That is why the tunnel was down, because it did not find a route for the tunnel source and destination in the vrf mgmt.
Now as soon as you remove the tunnel vrf mgmt command the router looks for the tunnel source and the tunnel destination in the global routing table, and since it finds both the tunnel becomes up.
As for the command "vrf forwarding mgmt" this simply puts the actual tunnel interface inside the vrf mgmt, not in the global routing table.
Both commands are not connected to each other, I mean you can have the tunnel in a vrf and the tunnel source and destination in a different vrf for example:
interface tunnel0
  ip vrf forwarding green
  ip address 1.2.3.4 255.255.255.0
  tunnel source 5.6.7.8
  tunnel destination 9.10.11.12
  tunnel vrf blue
The tunnel would belong to vrf green but it would look for the tunnel source IP " 5.6.7.8" and the tunnel destination IP "9.10.11.12" in the vrf blue.
Just one final note the tunnel source and destination must be in the same vrf, for our example above both the "5.6.7.8" and the "9.10.11.12" must be in vrf blue.
For further information please reference below documents:
http://www.cisco.com/c/en/us/td/docs/routers/10000/10008/feature/guides/122_31sb5/fs_gripvrf.html
http://www.cisco.com/c/en/us/support/docs/multiprotocol-label-switching-mpls/mpls/46252-grewithvrf.html
5 Replies 5
Rolf Fischer
Level 9
Level 9
... GRE Tunnel with vrf mgnt and the Tunnel source interface is not part of any vrf.
in such scenarios, you cannot use GRE keepalives.
You could adjust the OSPF timers instead.
Rolf
i removed the keep alive still the tunnel was down and then i removed the tunnel vrf mgmt and tunnel came up.
interface Tunnel1
 vrf forwarding mgmt
 ip ospf 2 area 0
 tunnel source 162.x.x.141
Logesh
Ah, correct; I've overlooked that.
The 'tunnel vrf <VRF>' command specifies the transport-vrf; in your case that's the global routing context.
Does the OSPF adjacency form now?
Yes the OSPF is Up now. Thanks for your help.
regards
Logesh
Hello Imanavalan,
interface tunnel0
  tunnel vrf blue
