GRE tunnel not failover if other interface down
Kevin Xau
I've configure IPSEC GRE tunnel between two routers that running EIGRP protocol. At branch site, it will use port FA0/0 to access some particular servers (ex: 192.168.158.3 ...) in HQ using policy-based routing. For accessing other IP address will use Tunnel 0 interface to connect to HQ.
However, when we try to test the fail-over by shutdown the FA0/0 interface, the Tunnel 0 interface down after a few second, it cannot fail-over traffic to Tunnel 0, we lost all connectivity from branch to HQ.
    a. Branch:
        • FA0/0: 200.1.1.1 /24
        • FA0/1: 101.19.26.132 /29
        • Vlan 1: 192.168.161.9 /24
        • Tunnel 0: 30.1.1.2 /24
    b. HQ:
      • FA0/0: 200.1.1.2 /24
      • FA0/1: 118.125.101.148 /29
      • Vlan 1: 192.168.158.253 /24
      • Tunnel 0: 30.1.1.1 /24
Here is configuration on Branch router, when we do "show ip route", there is no EIGRP route display.
version 12.4
service timestamps log datetime localtime
service password-encryption
hostname Branch
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
no aaa new-model
resource policy
memory-size iomem 25
clock timezone wst 8
ip cef
crypto isakmp policy 1
encr 3des
authentication pre-share
crypto isakmp key schaefer-key address 118.125.101.148
crypto ipsec transform-set schaefer-set ah-md5-hmac esp-3des
crypto map schaefermap 1 ipsec-isakmp
set peer 118.125.101.148
set transform-set schaefer-set
match address 100
interface Tunnel0
description Tunnel-to-HQ
ip address 30.1.1.2 255.255.255.0
ip tcp adjust-mss 1300
ip policy route-map clear-df
keepalive 10 3
tunnel source 101.19.26.132
tunnel destination 118.125.101.148
interface FastEthernet0/0
description Point-to-Point network
ip address 200.1.1.1 255.255.255.252
speed 100
full-duplex
interface FastEthernet0/1
description WAN network
ip address 101.19.26.132 255.255.255.248
speed auto
full-duplex
interface FastEthernet0/1/0
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Vlan1
description LAN network
ip address 192.168.161.9 255.255.255.0
ip policy route-map movex
router eigrp 100
redistribute static
network 30.1.1.0 0.0.0.255
network 172.19.4.0 0.0.3.255
no auto-summary
ip route 0.0.0.0 0.0.0.0 101.19.26.131
ip route 30.1.1.0 255.255.255.0 Tunnel0 130
ip route 172.19.5.0 255.255.255.0 192.168.161.8
ip route 172.19.6.0 255.255.255.0 192.168.161.8
ip route 172.19.7.0 255.255.255.0 192.168.161.8
ip route 192.168.158.0 255.255.255.0 200.1.1.2
ip route 192.168.158.0 255.255.255.0 Tunnel0 130
ip route 192.168.160.0 255.255.255.0 192.168.161.8
no ip http server
no ip http secure-server
access-list 100 permit gre host 101.19.26.132 host 118.125.101.148
access-list 102 permit ip 192.168.161.0 0.0.0.255 192.168.158.0 0.0.0.255
access-list 102 permit ip 192.168.160.0 0.0.0.255 192.168.158.0 0.0.0.255
access-list 102 permit ip 172.19.4.0 0.0.3.255 192.168.158.0 0.0.0.255
access-list 103 permit ip 172.19.4.0 0.0.3.255 host 192.168.158.3
access-list 103 permit ip 172.19.4.0 0.0.3.255 host 192.168.158.4
access-list 103 permit ip 172.19.4.0 0.0.3.255 host 192.168.158.5
access-list 103 permit ip 172.19.4.0 0.0.3.255 host 192.168.158.9
access-list 103 permit ip 192.168.161.0 0.0.0.255 host 192.168.158.3
access-list 103 permit ip 192.168.161.0 0.0.0.255 host 192.168.158.4
access-list 103 permit ip 192.168.161.0 0.0.0.255 host 192.168.158.5
access-list 103 permit ip 192.168.161.0 0.0.0.255 host 192.168.158.9
access-list 103 permit ip 192.168.160.0 0.0.0.255 host 192.168.158.3
access-list 103 permit ip 192.168.160.0 0.0.0.255 host 192.168.158.4
access-list 103 permit ip 192.168.160.0 0.0.0.255 host 192.168.158.5
access-list 103 permit ip 192.168.160.0 0.0.0.255 host 192.168.158.9
access-list 111 permit tcp any any
access-list 111 permit udp any any
route-map clear-df permit 10
match ip address 111
set ip df 0
route-map movex permit 10
match ip address 103
set ip precedence critical
set ip next-hop 200.1.1.2
route-map movex permit 20
match ip address 102
set ip precedence priority
set ip next-hop 30.1.1.1
Here is HQ router configuration: when we do "show ip route", there is no EIGRP route display.
version 12.4
hostname HQ
boot-start-marker
boot-end-marker
enable secret 5 $1$JPO5$Wjnsdwett312KbEu/DPlGEK1
enable password 7 06034346D4F41
no aaa new-model
resource policy
ip cef
encr 3des
crypto isakmp key schaefer-key address 101.19.26.132
set peer 101.19.26.132
match address 100
interface Tunnel0
description Tunnel-to-Branch
ip address 30.1.1.1 255.255.255.0
keepalive 10 3
tunnel source 118.125.101.148
tunnel destination 101.19.26.132
description IPLC network
bandwidth 10000
ip address 200.1.1.2 255.255.255.252
delay 120
speed 100
full-duplex
ip address 118.125.101.148 255.255.255.248
speed auto
full-duplex
interface Vlan1
ip address 192.168.158.253 255.255.255.0
router eigrp 100
redistribute static
passive-interface FastEthernet0/1
network 192.168.158.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 203.125.111.113
ip route 172.19.5.0 255.255.255.0 200.1.1.1
ip route 172.19.5.0 255.255.255.0 Tunnel0 130
ip route 172.19.6.0 255.255.255.0 200.1.1.1
ip route 172.19.6.0 255.255.255.0 Tunnel0 130
ip route 172.19.7.0 255.255.255.0 200.1.1.1
ip route 172.19.7.0 255.255.255.0 Tunnel0 130
ip route 192.168.160.0 255.255.255.0 200.1.1.1
ip route 192.168.160.0 255.255.255.0 Tunnel0 130
ip route 192.168.161.0 255.255.255.0 200.1.1.1
ip route 192.168.161.0 255.255.255.0 Tunnel0 130
no ip http server
access-list 100 permit gre host 118.125.101.148 host 101.19.26.132
access-list 102 permit ip 192.168.158.0 0.0.0.255 any
access-list 103 permit ip host 192.168.158.3 any
access-list 103 permit ip host 192.168.158.4 any
access-list 103 permit ip host 192.168.158.5 any
access-list 103 permit ip host 192.168.158.9 any
access-list 103 permit ip 172.19.5.0 0.0.0.255 any
access-list 103 permit ip 172.19.6.0 0.0.0.255 any
access-list 103 permit ip 172.19.7.0 0.0.0.255 any
access-list 103 permit ip 192.168.160.0 0.0.0.255 any
access-list 103 permit ip 192.168.161.0 0.0.0.255 any
set ip df 0
set ip next-hop 200.1.1.1
set ip next-hop 30.1.1.2
7 Replies 7
Richard Burts
The first issue that I notice is that you have configured crypto maps on both routers but neither router has its crypto map assigned to an interface. So the IPsec will not work. You need to fix that. There might be other issues but we can not be sure until this one is fixed.
Rick
Rick
Hi Richard,
So I need to put the crypto map on FA0/1 interface first?
Yes the crypto map should be applied on Fa0/1 on both routers.
Rick
Rick
I've configure the crypto map on both Fa0/1 interface, but still same problem. I've look in to previous configuration that working one on old router, it is no need to configure crypto map inside the interface. However, the port FA0/0 configuration on new router is Serial port on the previous router. So is it different?
I am puzzled about your statement that there was no need to configure crypto map inside the interface. If you want the traffic carried through the tunnel to be encrypted then there needs to be a crypto map on Fa0/1. If you say that there is not need for crypto map then it makes me wonder if I do not correctly understand what you are trying to accomplish. So please explain to me what you are trying to achieve.
Also can you clarify what is happening with the tunnel. In normal operation (when both Fa0/0 and Fa0/1 are up) is the tunnel up and passing traffic? And if you shut down Fa0/0 are you saying that the tunnel would then go down?
Rick
Rick
Sorry for confusing, for example,
 - At branch network, if we trace route to HQ 192.168.158.3, it will go via FA0/0 as policy routing. If this FA0/0 interface down, it will fail-over the traffic to the tunnel 0, but it is not happen in fact.
 - At branch network, if we trace route to HQ 192.168.158.10, it will go via tunnel 0.
The objective is we want to do the fail-over the traffic from FA0/0 interface to tunnel 0 once that interface down.
P/S: The above configuration is working fine on cisco router with serial interface for the 200.1.1.0/24 network. It can fail-over, after change to 1841 with FastEthernet interface, it cannot fail-over anymore.
Thank you for the clarification about how you expect it to work.
I repeat my question from a previous post:
knowing this might help clarify what is the issue.
It is interesting that the config did work on a router with a serial interface. I believe that something changed, beyond changing a serial interface for Ethernet. I did notice one issue on the HQ router. The default route is not valid. Here is the route
but the next hop is not valid. Was perhaps the serial interface using 203.125.111.114?
Rick
Rick
