GRE Tunnel not working in my test environment
wrainwater
I set up 5 routers. One hub server,three spokes and a middle router (emulating the cloud).
Here are my configs:
R1 (Hub) 37251
interface Tunnel0
ip address 192.168.0.1 255.255.255.0
no ip redirects
ip mtu 1416
ip nhrp authentication cisco123
ip nhrp map multicast dynamic
ip nhrp network-id 12345
tunnel source FastEthernet0/0
tunnel mode gre multipoint
tunnel key 12345
router ospf 1
log-adjacency-changes
network 200.10.0.0 0.0.0.255 area 0
end
interface FastEthernet0/0
ip address 200.10.0.1 255.255.255.0
duplex auto
speed auto
end
R2 (Spoke1) name 27252
interface Tunnel0
ip address 192.168.0.2 255.255.255.0
no ip redirects
ip mtu 1416
ip nhrp map multicast 200.10.0.1
ip nhrp map 192.168.0.1 200.10.0.1
ip nhrp nhs 192.168.0.1
tunnel source FastEthernet1/0
tunnel key 12345
end
interface FastEthernet1/0
ip address 25.0.0.2 255.0.0.0
duplex auto
speed auto
router ospf 1
network 25.0.0.0 0.255.255.255 area 0
R3 37253
interface Tunnel0
ip address 192.168.0.3 255.255.255.0
no ip redirects
ip mtu 1416
tunnel key 12345
ip address 35.0.0.3 255.0.0.0
duplex auto
speed auto
router ospf 1
network 35.0.0.0 0.255.255.255 area 0
R4 37255
interface Tunnel0
ip address 192.168.0.4 255.255.255.0
no ip redirects
ip mtu 1416
tunnel key 12345
ip address 45.0.0.4 255.0.0.0
speed 100
full-duplex
router ospf 1
network 45.0.0.0 0.255.255.255 area 0
R5 (Middle internet router)
ip address 45.0.0.5 255.0.0.0
ip ospf 1 area 0
speed 100
full-duplex
interface FastEthernet0/1
ip address 200.10.0.5 255.255.255.0
ip ospf 1 area 0
duplex auto
speed auto
ip address 25.0.0.5 255.0.0.0
ip ospf 1 area 0
speed auto
full-duplex
interface FastEthernet2/0
ip address 35.0.0.5 255.0.0.0
ip ospf 1 area 0
duplex auto
speed auto
When I do a show ip nhrp command on the Hub router I get no output
#Show Ip nhrp
I also got this constant flapping:
*Mar 1 02:40:51.171: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /200.10.0.1, src_addr= 45.0.0.4, prot= 47
Any helpful tips would be great. thanks
2 Accepted Solutions
Deepak Kumar
I didn't find the overlay routing configuration in your network configuration.
Let start with EIGRP configuration (You may go with Static/OSPF/BGP):
HUB:
router eigrp 1
router-id 1.1.1.1
no auto-summery
network 192.168.0.0
network <LAN Subnet>
interface Tunnel0
no ip split-horizon eigrp 1
Spoke:
router eigrp 1
router-id 2.2.2.2
no auto-summery
network 192.168.0.0
and try again.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak is absolutely right. Add the subnet of the tunnels to all your OSPF processes.
router ospf 1
network 192.168.0.0 0.0.0.255 area 0
I labbed your setup in GNS3, it works fine (except for the missing subnet in OSPF)...
8 Replies 8
Deepak Kumar
HUB:
router eigrp 1
router-id 1.1.1.1
no auto-summery
network 192.168.0.0
interface Tunnel0
Spoke:
router eigrp 1
router-id 2.2.2.2
no auto-summery
network 192.168.0.0
and try again.
Deepak Kumar
Deepak Kumar,
I have OSPF  configured in my setup. Will that not work?
As you shared configuration, The OSPF is enabled on the WAN interface, not for the DMVPN.
outer ospf 1
Deepak Kumar
Deepak Kumar,
router ospf 1
Thank you both for your responses. One last question.
What is the difference between a GRE tunnel and an IPSec tunnel?
Thank you for your response. What is the difference between a GRE and an IPSec tunnel?
a GRE tunnel is basically what you have. It means the data is encapsulated, not encrypted.
An IPSec/GRE tunnel is a tunnel that is encrypted. Have a look at the link below to see the difference between what you have, and what an encrypted tunnel config would look like...
https://www.cisco.com/en/US/technologies/tk583/tk372/technologies_white_paper0900aecd8029d629.html
There are basic technical differences are
GRE: the GRE tunnel data is encapsulated, not encrypted. once it will add one more IP header on the packet so the packet can route over the public internet but it is an open packet and anyone can read the packet including your data.
GRE is adding some more benefits as it is allowing Multicast traffic over and so Administrator can use Dynamic routing, Multicast etc over the GRE tunnel. You can apply IPSec over the GRE tunnel for encrypting the traffic.
IPSec: IPSec is for Encryption, integrity, and authentication. It is allowing only Unicast/anycast traffic.
Deepak Kumar
Deepak Kumar,
