GRE tunnel with HSRP
faghouri83
Hi everyone
I was wondering if it was possible to create a gre tunnel on two routers that are configured with hsrp. Il explain.
Lets say we have three routers, A, B, C. Routers A and B are configured with hsrp between them and they need to talk over a private wan link to router C.
If its possible then, would my source ip address be the virtual hsrp address or the physical ip address given to each routers A and B interface?
Hope I explained this clearly.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You would have two tunnels, one A<>C and the other B<>C.  On A and B, tunnel source would be an interface address on the router, which might be the physical interface or a loopback interface.  You would not use a HSPR address for tunnel source.
