HOW to check link bandwidth
salman abid
I'm having cisco1921/k9 router. I have applied for the upgradation of lease line from 1Mbps to 2Mbps. Today i informed by service provider that your link is upgraded now.
Interface Gig0/0 is conencted with SP.
Can anybody tell me how i can get to know that my link is upgraded from 1Mbps to 2Mbps.
immediate reply is required
thanks
Leo Laohoo
Go to www.speedtest.net.
Can't i check it through shome SHOW commands on router?????
You can check the stat via interface .
Sh interface
I would suggest setting the load interval to 30 second , this will give u better results of the bandwidth.you can set the load interval by issuing "load-interval 30" interface command.
And then again see the stat of the interface connected to ISP .
Sh int
