GRE-tunnel
komuja1
Is this normal behaviour when I have a GRE tunnel between PE and CPE? When I tried to icmp from PE to CPE tunnel address I got the following output in CPE and the ping fails.
Jul 4 16:52:57: Tunnel1: adjacency fixup, 10.36.73.1->10.36.85.156, tos=0x0
The tunnel is up but ping fails and I have configured ip mtu 1476 and ip tcp adjust-mss 1436 in CPE.
The same configuration works in other CPE and configuration is same.
6 Replies 6
royalblues
Level 10
Level 10
Can you post the configurations..
Here are the configurations:
CPE
interface Tunnel1
ip address 10.10.10.1 255.255.255.252
ip mtu 1476
tunnel source FastEthernet0.1567
tunnel destination 10.10.10.5
interface FastEthernet0.1567
encapsulation dot1Q 1567
ip address 10.10.11.1 255.255.255.252
ip accounting output-packets
ip route 0.0.0.0 0.0.0.0 10.10.10.2
ip route 10.10.10.5 255.255.255.255 10.10.11.2
PE
interface Tunnel10013
ip vrf forwarding customer_a
ip address 10.10.10.2 255.255.255.252
tunnel source Loopback1003
tunnel destination 10.10.11.1
end
interface GigabitEthernet0/3.111
encapsulation dot1Q 111
ip address 10.10.11.2 255.255.255.252
interface Loopback1003
ip address 10.10.10.5 255.255.255.255
ip route vrf customer_a 10.10.11.0 255.255.255.252 GigabitEthernet0/3.111 10.10.11.1
I can ping between link address (also MTU 2000)but norman ping won't work over the tunnel. The link from CPE to PE goes via ME-switch.
I also have same configuration where CPE and PE are connected via ATM network and it works fine.
Jarmo
I have been trying to understand the relationship of the addresses given in the error message in your original post:
and the addresses shown in the partial config that you posted. I am confused. Can you clarify what the addresses are in the error message and how they relate to the routers running the tunnel?
Rick
Rick
Jarmo,
I agree with Rick that it's unclear how the error message relates to the problem you described. It sounds like you are able to ping across the lan link fine but it only fails when you ping across the GRE tunnel. You have the MTU set to 1476 on the CE tunnel int but not on the PE. Can you set the MTU to 1476 on the PE tunnel int 10013 as well and test?
Sundar
I made a change the configrations in yesterday and I posted a different config's..sorry about that.
this is the original config and I also sent a debug messages when this configration is valid and when I tried to icmp PE to CPE. I will try to set PE tunnel 10013 MTU 1476 and inform you.
CPE
interface Tunnel1
ip address 10.36.85.145 255.255.255.252
ip mtu 1476
tunnel destination 10.36.85.156
ip address 10.36.73.1 255.255.255.252
ip route 0.0.0.0 0.0.0.0 10.36.85.146
ip route 10.36.85.156 255.255.255.255 10.36.73.2
debug messages in CPE
Tunnel1: GRE/IP encapsulated 10.36.73.1->10.36.85.156 (linktype=7, len=80)
IP: tableid=0, s=10.36.85.146 (Tunnel1), d=10.36.85.145 (Tunnel1), routed via RIB
IP: s=10.36.85.146 (Tunnel1), d=10.36.85.145 (Tunnel1), len 100, rcvd 3
PE
ip address 10.36.85.146 255.255.255.252
tunnel destination 10.36.73.1
ip address 10.36.85.156 255.255.255.255
ip address 10.36.73.2 255.255.255.252
ip route vrf customer_a 10.36.73.0 255.255.255.252 GigabitEthernet0/3.111 10.36.73
The debug in PE
Tunnel10013: GRE/IP to classify 10.36.73.1->10.36.85.156 (len=130 ttl=254 tos=0x0)
br
Jarmo
Jarmo
It would be easier to know if it were normal if we knew exactly what debugs you had running and what version of IOS you were running.
This message on the CPE indicates that you did receive 3 packets over the tunnel, which would seem to be the icmp that you sent:
It is not clear whether you sent responses and if not why not. I assume that this debug was from debug ip packet on CPE. Are you running this debug also on PE? If not it would help to see that debug on both routers.
Rick
Rick
