GRE tunneling
ColForbin
I have a remote site I need to make some tunneling changes to. It connects back to the core router by way of a layer 3 circuit to another remote location that has a dedicated p2p to the core. R1<>L3circuit<>R2<>leasedline<>R3core
R1-R2have a gre tunnel.  L3 circuit is just transport the isp does no routing.
i need to encrypt traffic from R1 to R3 and back. 2 questions naturally
what’s the best way to accomplish if that means replacing hardware so be it
and two, best way given constraints of current hardware?
19 Replies 19
R2 use static route egress direct connect to R3 to learn R3 LO
In R2
Ip route 3.3.3.3 255.255.255.255 <R3 IP of interface connect to R2>
Makes sense...loopbacks are the key, need to test it out and report back, need some time but thanks for the advice regardless, its a different way of looking at it.
You are so welcome
MHM
Well only way I can ping R1 loopback from R3 is to source from the loopback which should be ok because that’s my source on the new tunnel. Tunnel comes up.
If I do just a gre:
Sh int tunn2 from R3 shows mtu 1476
sh int tunn2 from R1 shows mtu 1452 so double encaps.
If I do a dmvpn setup it’s the same.
with vti tunnel comes up but I can’t ping the tunnel addresses. Regardless of that the r1 mtu shows 1476. Vti allows my r3 to come up with no encapsulation so it’s showing 1500 which is fantastic. But the other end on r1 is 1476 so it is encapsulating that underlay tunnel.
Any other thoughts feel free to reach out. Thanks for the time much appreciated.
""R1-R2have a gre tunnel.  L3 circuit is just transport the isp does no routing.
i need to encrypt traffic from R1 to R3 and back. 2 questions naturally""
This your requirements and it need mandatory two tunnel.
Since we use two tunnel R1 must do dual encap' other routers only have one encap
To test ping from R1 to R3 you need to specify LO to check underlying abd you can use tunnel IP to check overlying
MHM
