GSR and access-list
Antonio_1_2
I have applied named access-list in output direction on 1GE interface on GSR12400 (IOS XR 3.4),
but there is no matches. Counters doesn't increase although access-list blocks or permits certain packets (access-list works as it should).
Why is it so?
thnaks in advance,
A
Rivalino Tamaela
Hi Antonio,
I assume the counter you meant is the counter of access list. If this is the case, you need to enable hardware counter in access-list you applied in interface.
Look example I did in my lab:
RP/0/RP0/CPU0:CRS4A#show run int gi0/1/0/3
Thu Jan 27 11:14:45.691 PST
interface GigabitEthernet0/1/0/3
cdp
ipv4 address 12.1.1.2 255.255.255.0
ipv4 access-group ACL egress hardware-count interface-statistics
RP/0/RP0/CPU0:CRS4A#show access-lists ipv4 ACL
Thu Jan 27 11:16:18.552 PST
ipv4 access-list ACL
10 permit icmp any host 10.1.1.2
20 permit ipv4 any any
RP/0/RP0/CPU0:CRS4A#ping 10.1.1.2
Thu Jan 27 11:12:27.749 PST
Sending 5, 100-byte ICMP Echos to 10.1.1.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 2/3/8 ms
RP/0/RP0/CPU0:CRS4A#show access-lists ipv4 ACL hardware egress interface gigabitEthernet 0/1/0/3 location 0/1/cpu0
Thu Jan 27 11:18:45.104 PST
10 permit icmp any host 10.1.1.2 (5 hw matches)
20 permit ipv4 any any (2 hw matches)
Hardware counting is not enabled by default for IPv4 ACL, but it is enabled by default for IPv6 ACL.
Please refer to the following documentation to understand better:
Rivalino Tamaela
Hi Antonio,
cdp
Thank you very much Rivalino,
A.
