Hi Folks, We are looking at buying an ASR1001 but I'm confused by the Licenses and I've struggled to find the information in the cisco data sheets. The router will need to run IPSEC on gre tunnels and I figure that I need the IPSEC license (FLSASR1-IPSEC) do I also require the Advanced IP Services license? or is all that is required the IPSEC license? Is there some sort of list that shows the feature set of each license, they cost the same amount so I'm not sure which license fits what we require best or if we need both. Cheers Alex
