Guest Wireless Access
gleung001
I'm not a network expert but I am attempting to finish up a project started by someone else which is a setting up a guest wireless network. I'm having an issue where the machine connects to the SSID but doesn't get an ip address from the DHCP server set on the firewall. They all get the 169.254.x.x. Here's the equipment involved:
Cisco 3750G switch
Cisco ASA 5510 Firewall - IP 10.0.1.254
Cisco 2500 Series Wireless Controller
I've attached some screenshots. Let me know if you need more information. Thanks.
22 Replies 22
Sorry John, I'm not familiar with the gi1/0/1.200. I looked through our switch config and I don't see anything similiar to that. This is what's on the interfaces section on ASA.
It's there at e0/3.200 for vlan 200. Can you connect a laptop to your core switch and make it a member of vlan 200 to see if it will get an address? We need to rule out that it's a dhcp issue and not wireless...I'll start labbing this up if your dhcp doesn't work from the laptop.
What port does the ASA connect to on the 3750?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Hey john, do you mean configure vlan200 on a port on switch and plug laptop to it to see if it pulls an IP? Interface 1 (inside) on Firewall connects to 1/0/1 of switch. Interface 3 (trunk?) of Firewall connects to 1/0/2 of switch. Not sure if it makes any difference but Interface 0 (outside) of Firewall goes to 1/0/48. Is that what you're looking for?
Yes sir...that's it. Can you connect the laptop to the switch and see if you get an address? I'm labbing this up as well...
HTH,
John
gotcha, going to leave the office soon but will try this out tomorrow when I get in..thanks for your help john.
No worries. I'm going to be out the rest of the week, so someone else may be able to pick up hopefully. I labbed this up, and the ASA will definitely hand out addresses via a helper address, so you should be okay there. This is just something that has to be found, but you'll get it working.
HTH,
John
John, do I need set the ip helper on switch and on WLC interfaces section as well? Or does setting it on WLC suffice? Also to verify, the ip helper is 10.0.1.254 or 192.168.90.254?
Gary,
I labbed this up and I don't have any issues with it. One thing that I realized after you posted your config is that the ASA is trunked to the vlan that you're guest wireless is. That being said, you won't need a helper on that vlan. The guest will request an address by broadcasting, and since vlan 200 is part of the trunk on the ASA, the ASA will get it. I think your dhcp setup looks fine, but then again you should still put a laptop on the 3750 and make it an access port on vlan 200. If you get an address, the problem is with the WLC. Unfortunately, I don't have experience with those.
HTH,
John
