Guestshell not working in ESR 6300 ()
swa64211
Hey guys,
I'm trying to use guestshell to run scripts on router but I'm not able to enable guestshell. I have tried all the fixes suggested for similar queries in the forum but none of them yielded any results. (version 17.4.1)
*May 15 17:43:18.305: %IM-6-IOX_START_INFO: R0/0: ioxman: guestshell cannot be started because it is not installed
*May 15 17:43:18.306: %IM-6-START_MSG: R0/0: ioxman: app-hosting: Start failed: guestshell cannot be started because it is not installed
I'll attach few lines from the log which may help to analyse the issue.
Any help is appreciated, thank you
log -
router#sh iox-service
IOx Infrastructure Summary:
IOx service (CAF) : Running
IOx service (HA) : Not Supported
IOx service (IOxman) : Running
IOx service (Sec storage) : Not Running
Libvirtd 5.5.0 : Running
Dockerd 18.03.0 : Running
router#sh iox-server
% Invalid input detected at '^' marker.
router#sh app
router#sh app-
router#sh app-hosting ?
debug app-hosting debug
detail Detail information about appliance
device Available device information
infra app-hosting framework infra details
list List the appliance
resource available resources
utilization Utilization information about appliance
router#sh app-hosting lis
router#sh app-hosting list
No App found
router#sh app-hosting re
router#sh app-hosting resource
CPU:
Quota: 33(Percentage)
Available: 33(Percentage)
Quota: 1617(Units)
Available: 1617(Units)
VCPU:
Count: 1
Memory:
Quota: 512(MB)
Available: 0(MB)
Storage space:
Total: 2798(MB)
Available: 1953(MB)
router#
router#user
router#usern
router#usern
router#usern
router#userna
router#conf
router#configure t
Enter configuration commands, one per line. End with CNTL/Z.
router(config)#use
router(config)#user
router(config)#userna
router(config)#username ?
WORD User name
router(config)#username cisco priv
router(config)#username cisco privilege 15 pass
router(config)#username admin privilege 15 password 0 cisco
WARNING: Command has been added to the configuration using a type 0 password. However, type 0 passwords will soon be deprecated. Migrate to a supported password type
router(config)#
*May 15 17:41:42.660: %AAAA-4-CLI_DEPRECATED: WARNING: Command has been added to the configuration using a type 0 password. However, type 0 passwords will soon be deprecated. Migrate to a supported password typeapp-ho
router(config)#app-hosting app
router(config)#app-hosting appid ?
WORD no description
router(config)#app-hosting appid guestshell
router(config-app-hosting)#
router(config-app-hosting)#?
app-default-gateway Application default-gateway
app-default-ipv6-gateway Application default-ipv6-gateway
app-device Application device information
app-resource Application resources
app-vnic Virtual Network Interface
default Set a command to its defaults
exit Exit sub-mode
name-server0 Name server IP Address
name-server1 Name server IP Address
name-server2 Name server IP Address
name-server3 Name server IP Address
name-server4 Name server IP Address Mgmt
no Negate a command or set its defaults
start Activate and Start/Run the Application
router(config-app-hosting)#re
router(config-app-hosting)#resource ?
profile Application profile name
router(config-app-hosting)#resource cus
router(config-app-hosting)#resource cus?
% Unrecognized command
router(config-app-hosting)#resource custom ?
router(config-app-hosting)#resource custom?
router(config-app-hosting)#st
router(config-app-hosting)#start ?
<cr> <cr>
router#
*May 15 17:43:30.571: %SYS-5-CONFIG_I: Configured from console by console
router#^Z
router#sh ver
Cisco IOS XE Software, Version 17.04.01
Cisco IOS Software [Bengaluru], ISR Software (ARMV8EL_LINUX_IOSD-UNIVERSALK9_IOT-M), Version 17.4.1, RELEASE SOFTWARE (fc5)
balaji.bandi
make sure you have enough space available - check the installation guide
until all running as expected you can not install application.
#show iox-service
IOx service (CAF) 1.11.0.5 : Running
IOx service (HA) : Running
Libvirtd 1.3.4 : Running
Application DB Sync Info : Available
Sync Status : Disabled
https://developer.cisco.com/docs/iox/#!ie3x00-series/enabling-cisco-iox
BB
