Guidance on redundancy solution
shree_nav
Dear All,
We want to implement redundancy for our  LAN-to-WAN connectivity. There are 2  redundant L3 swithches running  HSRP connected to the LAN, and there is a single WAN router(7206 VXR,  with NPE-G1). The WAN router is connected only one L3 switch. So current  solution is such that ports on both L3 have been configured with the  correct HSRP VLAN groups for the router, and in event of a failure of  active  L3,  a cable swap to standby L3 will do the  trick. Now the  problem is that if we actual benefits of HSRP is to be realised, we have  to have another  LAN connection from router to L3. All three Gigabit LAN  ports from  the NPE have been used up.Which port adaptor do i use to  gain additional Gi lan ports? Will this be the correct solution?What will be the layer3 considerations on the LAN ports on the router  in such a case?
Pavol Golis
http://www.cisco.com/en/US/products/hw/modules/ps2033/ps2595/index.html
or
http://www.cisco.com/en/US/products/hw/modules/ps2033/ps2546/index.html
So either 2xFast Ethernet (metallic) of Gigabit Ethernet with GBIC, you can buy GBIC for 1000-BASE-T (metallic). If your WAN link is slower than 100Mbps then 2xFastEthernet PA should be cheaper & sufficient and gives you one extra physical port.
From the design perspective, you can either run routing protocol between 7200 and L3 switches, and let it take care of redundancy or run HSRP on router ports (this should work, but I haven't tried it)
Pavol Golis
or
aqeel.karim
A drawing would help visually, if you could produce it. But what I can see if the following:
                   Current
                    C7206
                    Gi0/0
                  C3700 series
                 Gi1/1     Gi1/2
         C4500 Series  C4500 series
                   |      |_____|    |
                   |        Gi0/2    |
                   |         VL2     |
                 Gi2/1             Gi2/1
                 Vlan2            Vlan 2
                HSRP1         HSRP2
                  Gi2/2            Gi2/2
                       VLAN2-Users
                                       Proposed
                                        C7206
                         Gi0/0                                       Gi1/0
              C3700 series                                         |
                 Gi1/1                                                 |
                   |                                        Gi0/4  Gi0/1
         C4500 Series                               C4500 Series
                   |      |_____________________|        |
                   |                  Gi0/2                           |
                   |                   VL2                            |
                 Gi2/1                                           Gi2/1
                 Vlan2                                         Vlan 2
                HSRP1                                        HSRP2
                  Gi2/2                                           Gi2/2
                                     VLAN2-Users
So, you have redundancy on the LAN via different modules but technically, you are still single threaded because both LANs are on the same chassis. Also, you are single threaded because you have one WAN router with an interface. And your stating an additional port on the 7206 is becoming available but you're not sure how to achieved HSRP when a interface opens. Correct?
You have good and bad situation...
1. Even if you open a another interface on the C7206 for the you appear to still be signle homed on your distro/L3 switch. But you have a valid question where to place the new PA on the 7206. Cisco uniquely assigns PA BW points for certain modules in the 7200 series routers. See the below link
http://www.cisco.com/en/US/docs/routers/7200/configuration/7200_port_adapter_config_guidelines/3875In.html#wp1115595
But when you perform this addition, it should be pretty simple. Move an interface on Vlan 2 with a correct IP. Of course, depending on how you subnet is managed you may find a IP address out of range if you start with the normal GW addrs of .1 - 4.
2. Better option would be to bypass your Distro switch and go directly into your L3 switch. This will allow you to have a full redundant network with redundant interfaces and devices. And if ever such a time arises where you have more than 1 network that has priorities a simple sub-interfaces on the 7206 will accomplish that. With trunks placed on the L3 switch instead of routed IP's.
My other issue as I list this is that HSRP is on the user switch which places routing and switching on the same device. But really the HSRP process should be done either on the router or the distro switch as it will see the failures first. In which most times comes from the WAN and not the LAN. If the LAN fails then the users will definitely experience an outage but if the WAN fails a percentage of business can continue locally with printing, resource servers and things of that nature. Remember the approach should be the 80/20 rule and not the 20/80.
