Guidlines for CCNP-(ROUTE 642-902)
Yashwant Aditya
Can any one plss guide me how to prepair for CCNP-Route Exam (ROUTE 642-902).
Thank you very much.
mrmozaffari
It is easiest exam for Ccnp.
Get the book ,you can buy it on ciscopress website or if you search you will find it and you can download it for free.
Next step is simulation, go for gns3 download it, it is free. Find ios on internet for 3700 and 2600 cisco routers, don't get the high feature basic is enough, cause when you run the basic feature the routers come up very fast.
Consider 1 to 2 month study for route if you really want to learn it.
Finally use examcollection website and download the test for 642-902 and thats it.
Abzal
Level 7
Level 7
Here is appropriate forum where you can ask or find answers for your questions:
https://learningnetwork.cisco.com/
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Hi Yashwant,
1. Buy the cisco press book or download a free pdf copy from the internet. search for it and you will find heaps of sources.
2. Do heaps of labs on GNS3
3. come and visit CSC forums regulalry and post your questions etc.
That should be it All the best.
Go For
CBT Nuggets and its has GNS Pactice Labs included that will help you a lot.
*** Do Rate Helpful Posts***
Jawad
