Hanging off Nat entry after router and circuit change on DMVPN
Jonnyballgame34
Greetings-
I've got a DMVPN router that serves as a spoke for it's site.  I recently upgraded the router to a 1941, and at the same time, went from 2 serials to a fiber/ether, and from 3mb to 10mb.
Outside of the obvious changes, (interfaces, bandwidths, etc), the configuration is exactly the same.  However a few days after the swap, the new router's CPU started getting swamped and took things down.    on reboot it came back up, but it happened a couple of days later.  I traced it to a problem with NAT translations hanging--seems it take a couple of days for them to build but eventually the overwhelm the processor.
I've seen several cased of people having this problem, but I can't find any that say they can fix it.  Next step is an IOS upgrade, but it's a nuisance to take down the site, so I'm hoping to have something more than a best guess before I try it.  Has anyone see this before/  thanks
hard to say, can you post your config ?
You might want to try 'mode transport' for your VPN tunnels.
Do you have the below configured ?
crypto ipsec nat-transparency udp-encapsulation
If not, add that to your configuration.
Hello
Have you tried decreasing the nat default parent/child timeout valuess for tcp/udp - default is 24 hrs =86400secs
example:
ip nat translation timeout 3,600 (1 hr)
ip nat translation tcp-timeout 1800 (30 mins)
ip nat translation udp-timeout 1800 (30 mins)
res
Paul
Kind Regards
Paul
