Have two routers, one subinterface on each serial connected via Cloud using FR; cannot ping each other
nicolas873
First of all, this is the first time for me posting on these forums so I hope that my post abides by the rules.
I'm new to configuring Frame Relay and started off with a simple topology:
Since I intend to extend this topology as soon as I've managed to get it working, I decided to use subinterfaces. s0/3/0.103 on R1 and s0/3/0.301 on R2.
R1#sh run
Building configuration...
Current configuration : 848 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R1
license udi pid CISCO2911/K9 sn FTX15244W9S
spanning-tree mode pvst
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
shutdown
interface Serial0/3/0
no ip address
encapsulation frame-relay
interface Serial0/3/0.103 point-to-point
ip address 10.1.10.1 255.255.255.0
frame-relay interface-dlci 103
interface Serial0/3/1
no ip address
shutdown
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
R2#sh run
version 15.1
hostname R2
license udi pid CISCO2911/K9 sn FTX1524PJ1P
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
no ip address
interface Serial0/3/0.301 point-to-point
ip address 10.1.11.1 255.255.255.0
frame-relay interface-dlci 301
no ip address
shutdown
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Cloud has been configured as follows:
Serial0: DLCI 301 Name zuR2
Serial1: DLCI 103 Name zuR1
Frame Relay:
Serial0 - zuR2 <-> Serial1 - zuR1
Any advice I can get is greatly appreciated.
Rolf Fischer
Level 9
Level 9
Hi Nicolas,
welcome at CSC!
You're using Frame-Relay, a layer-2 technology, to interconnect the router's subinterfaces.
Why are the subinterfaces in different IP-subnets when there's no routing instance in between?
Actually, due to the logic of FR P2P-interfaces, you could add static routes to make it work; but since you can't specify a next-hop IP-address, you would have to configure the exit-interface instead, which is not recommended:
R1#show ip interface brief s0/0.103
Interface                  IP-Address      OK? Method Status                Protocol
Serial0/0.103              10.1.10.1       YES manual up                    up
R1#show ip route static
S       10.1.11.0 is directly connected, Serial0/0.103
R1#ping 10.1.11.1
Sending 5, 100-byte ICMP Echos to 10.1.11.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/37/64 ms
Best regards
Rolf
