having problem with serial port config on 1941 series router
xwashington
                   Trying to configure serial ports on a Cisco series 1941 router. The command for serial is not available in the software for me to config any serial port on this router. I believe the proble is I need the correct software version that supports this but I cannot find it anywhere. Can anyone help me???
Ivan Shirshin
Hello Xavier,
Please clarify which commands are you trying to configure and also share "show version" and "show inv".
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
