HDLC debug output not available after IOS 15.7 upgrade
I recently upgraded my 2951 Router from IOS 15.4 to 15.7.  Before the upgrade, I woud type
debug serial int
to get the HDLC debug output
and I would get the following debug output
HDLC myseq 6, mineseen 6*, yourseen 7, line up
Now, after the upgrade, I can't get those debug messages anymore.  Any ideas?
It wasn't a problem, specifically, with the debugging system.
It turns out, that in upgrading to the newer version of the firmware, the ignore-dcd setting became unset at some point. I need to ignore that signal, because there is inline crypto that brings the interface down until it has re-synchronized with it's peer. Once I set that to true, the keepalive messages began to run continuously as expected.
Thanks.
is it possible that the default encapsulation on serial interfaces has changed from HDLC to PPP in that release ?
Thanks.
