HDLC Layer 2 Address
Ahmed Mukhtar
   Although i teach CCNA and CCNP and i still dont understand the concept of HDLC...
i know that Ethernet uses MAC addresses at layer 2, Frame Relay uses DLCI numbers at layer 2 ok great....Then what does HDLC use????
Dosent HDLC has a layer 2 address too? like FR or Ethernet??
Please do clarify me in simple words
Thank You
Richard Burts
In simple words - HDLC does not use a layer 2 address to identify devices on the connection. HDLC does not need a layer 2 address in the same way that Ethernet or Frame Relay do. With Ethernet and Frame Relay there can be multiple remote devices connected on the media and you need a layer 2 address to uniquely identify each device. With HDLC it is a point to point connection and there is never more than one other device connected and no layer 2 address is required.
Rick
Rick
Thanks Richard Nice explanation...
but still iam a litlle bit confused....can u give me a link which can explain all this...
And Do tell me about SLARP which is used in HDLC
Thank You
Here is a link that talks about Cisco HDLC and about SLARP. I hope that you find it useful.
Rick
Rick
