HDLC synchronous or asynchronous??
echipbk12
In my Accessing the WAN book, it says "HDLC uses synchronous serial transmission to provide error-free communition between 2 points". And on Wikipedia it says "HDLC frames can be transmitted over synchronous or asynchronous links". So does HDLC use synchronous or asynchronous transmission?? Thank you.
tobyarnett
HDLC can be used on both synchronous and asynchronous links. Your book is likely specifying how the protocol is used on a standard WAN link (is DS3 or T1) in which case both of these links are synchronous. There are other implementations of HDLC though that is used across asynchronous links. I believe wiki is accounting for all uses and your book is tar getting common usage on a WAN circuit.
Toby
Sent from Cisco Technical Support Android App
-Toby
Please don't forget to rate any helpful post.
_____________________________________
There are no great limits to growth because there are no limits of human intelligence, imagination, and wonder.
- Ronald Reagan
tobyarnett
Toby
-Toby
- Ronald Reagan
