Help basic configuration DHCP-server on routers - IPv4 and IPv6
marfaa
This is my first time asking a question here and I really hope someone can help. I am working on a assignment witch is:
"Configure DHCP-servers on R1, R2 and R3. The DHCP-server on each router should be responsible of handing out IP-addresses and gateway-information to hosts connecting to the LAN at the routers GigabitEthernet0/0 interface. Remember to reserve the first couple of addresses in the subnet to avoid IP conflicts with hosts having a static IP.
Connect a pc to each LAN and verify that the PC recieves both an IPv4 address (from DHCP), and an IPv6 address (from SLAAC)."
I thought I had configured it correctly, but when I tried to connect a PC it did not work.
The commands I used on each router was:
IPV4
ip dhcp excluded-address 100.64.1.1 100.64.1.5
Ip DHCP pool LAN-POOL-1
Network 100.64.1.0 255.255.255.0
Default-router 100.64.1.1
End
IPV6
Ipv6 unicast-routing
Ipv6 DHCP pool IPV6-SLAAC1
Exit
interface GigabitEthernet0/0
Ipv6 DHCP server IPV6-SLAAC1
Ipv6 nd other-config-flag
Exit
Ipv6 enable
Ipv6 address autoconfig
Is it something that I am missing or have done wrong?
I am attaching a screenshot of my topology and output of some commands.
I also tried to use the command "show ip dhcp server statistics", but it just says that the command is invalid... Same with the command "show ip dhcp". Anyone know why?
you have configured stateless IPv6 DHCP, the configs (also the IPv4) look correct.
Is this a 'real' network, connected to an actual server, or a simulated network ?
