[Help] Basic Setup for Cisco C1111-4PLTE to Act as Main Home Router
natuan0
Hi everyone,
I’m trying to set up my Cisco C1111-4PLTE (running IOS XE 17.12.4) as the main router for my home network.
My Goal:
  • Use Cellular0/2/0 (LTE) as the primary WAN connection.
  • Use the 4 LAN ports (GigabitEthernet0/1/0 to 0/1/3) to serve home devices. If possible, use the 2 WANs as LANs because I only use LTE as WAN.
  • Provide DHCP for the home network in subnet 192.168.5.0/24, with router IP 192.168.5.1. I will connect an Wifi AP to provide Internet for the house
Current Issue:
  • I cannot even ping 8.8.8.8 from the router CLI console.
  • Cellular0/2/0 interface shows “up” and gets an IP address from my LTE provider.
  • I set up NAT rules via Web UI, but something seems to be missing.
  • DHCP on LAN works — my laptop receives an IP in 192.168.5.0/24.
  • I can’t access the Internet from the router or from LAN devices.
Below is the config file. Really appreciate any guidance — I'm stuck and just want a simple Internet setup to start with. Thanks!
version 17.12
service call-home
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
platform hardware throughput crypto 50000
hostname BSRouter
boot-start-marker
boot system flash:c1100-universalk9.17.12.04.SPA.bin
boot-end-marker
logging console emergencies
no aaa new-model
clock timezone ICT 7 0
ip dhcp excluded-address 192.168.2.0 192.168.2.99
ip dhcp excluded-address 192.168.5.0 192.168.5.99
ip dhcp pool HomeLAN
 network 192.168.5.0 255.255.255.0
 default-router 192.168.5.1
 dns-server 8.8.8.8 8.8.4.4
 lease infinite
login on-success log
subscriber templating
vtp version 1
crypto pki trustpoint TP-self-signed-2258791517
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2258791517
 revocation-check none
 rsakeypair TP-self-signed-2258791517
 hash sha256
crypto pki trustpoint SLA-TrustPoint
 enrollment pkcs12
 revocation-check crl
 hash sha256
crypto pki certificate chain TP-self-signed-2258791517
crypto pki certificate chain SLA-TrustPoint
diagnostic bootup level minimal
license udi pid C1111-4PLTELA sn FGL2415L2VY
memory free low-watermark processor 65711
enable secret 9 xxxx
enable password xxxx
username admin privilege 15 password 0 Xsw21q@z
redundancy
 mode none
controller Cellular 0/2/0
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
 ip address 192.168.100.1 255.255.255.0
 negotiation auto
interface GigabitEthernet0/0/1
 no ip address
 shutdown
 media-type rj45
 negotiation auto
interface GigabitEthernet0/1/0
 switchport mode access
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
 switchport
interface GigabitEthernet0/1/3
 switchport
interface Cellular0/2/0
 description Primary_
 ip address negotiated
 ip nat outside
 ip tcp adjust-mss 1460
 dialer in-band
 dialer-group 1
 ipv6 enable
 pulse-time 1
interface Cellular0/2/1
 no ip address
 shutdown
interface Vlan1
 ip address 192.168.5.1 255.255.255.0
 ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface Cellular0/2/0 overload
ip nat inside source list WEBUI-NAT-ACL interface Cellular0/2/0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0/2/0
ip ssh bulk-mode 131072
ip access-list extended WEBUI-NAT-ACL
 10 permit ip any any
ip access-list standard 1
 10 permit 192.168.2.0 0.0.0.255
dialer-list 1 protocol ip permit
snmp-server community public RO
control-plane
line con 0
 transport input none
 stopbits 1
line vty 0 4
 password xxxx
 login
 length 0
 transport input ssh
line vty 5 14
 password xxxx
 login
 transport input ssh
call-home
 ! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
 ! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
 contact-email-addr sch-smart-licensing@cisco.com
 profile "CiscoTAC-1"
  active
  destination transport-method http
end
pieterh
I suggest you NAT the  HomeLAN subnet instead
I agree with @pieterh that the configuration of the acl used for NAT is not correct and should be fixed. But that is not the only problem. I note this in the OP " cannot even ping 8.8.8.8 from the router CLI console". Pinging from the console would use the outside interface and would not need NAT. I suggest adding a parameter to your default route
ip route 0.0.0.0 0.0.0.0 Cellular0/2/0 dhcp
Rick
