HELP: changing vlan with a script
idan.shemeah
Hello ,
I would be happy to have your help on this issue because I have trying for a lot of time to find a quick and easy solution, which unfortunately, I can not find.
I'm trying to write a simple script with which new employees, who have no knowledge of working with a Cisco switch, will use it to change certain ports from one VLAN to another VLAN.
I tried to deal with PERL program but it was too complicated.
I would appreciate you if you will help to build this script.
Thanks in advance,
Idan.
cadet alain
Hi Idan,
You can use switch macros to do this.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.2_25_see/configuration/guide/swmacro.html
Regards.
Alain.
Thanks for the advice, but the solution presented here is still not answer me about the problem for which I want to make this script.
I want to simplify the handling of changing the VLAN to employees who do not know how to work with switches.
By the solution you presented, employees will need to log in using TELNET to the switch and working with macros commands.
idan.shemeah
Someone help please ?
themhuyen
May be too late now, but this will do the job.
Note: This script is written for the NMS that runs on Solaris.
#!/bin/bash
#Written by Them Huyen - Australia.
#This script is to config the Cisco router/switch from a Solaris NMS.
#File hostname is a list of devices with 3 columns, seperate by the space: first column is the hostname/ip address
#+ the second column is the switch/router interface detail e.g. fa0/1, the 3rd column is the vlan info e.g 100
#File hostname should look like this: 10.0.0.1  fa0/1  100
cat hostname | while read host int vlan
   do
      ping $host >/dev/null
      if [ $? = 0 ]; then
          (echo "YOUR_LOGINID";\
           echo "YOUR_LOGIN_PASSWD";\
           echo "conf t",\
           echo "interface $int";\
           echo "switchport access vlan $vlan";\
           echo "end";\
           echo "show run int $int";\
           echo "wri mem";\
           echo
           echo "exit";\
           sleep 10) 2>/dev/null | telnet $host;
           echo
           echo "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
        else
           echo -e "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
           echo -e "Device \"$host\" is unreachable"
           echo -e " "
      fi
done | tee config-Result.txt
