How to implement bandwidth distribution in 1841 router
darksilver26
hello cisco enthusiast.
I would like to ask help from you how would this configuration goes.
I got a 5MBps Lease Line Connection via FAST ETHERNET PORT. i got a Cisco 1841 Router.
I want to distribute bandwidth in this ratio 2MBps/2MBps/1MBps
2MBps = Office Connection
2MBps = Computer Laboratory Connection
1MBps = WIFI Connection
1841 has only 2 Fast Ethernet ports
so im planning to add up a 2modules of 2-Port Fast Ethernet High-Speed WIC for Cisco Integrated Services Routers
thank you
18 Replies 18
Joseph W. Doherty
Disclaimer
The     Author of this posting offers the information contained within this     posting without consideration and with the reader's understanding  that    there's no implied or expressed suitability or fitness for any   purpose.   Information provided is for informational purposes only and   should not   be construed as rendering professional advice of any kind.   Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In     no event shall Author be liable for any damages whatsoever   (including,   without limitation, damages for loss of use, data or   profit) arising  out  of the use or inability to use the posting's   information even if  Author  has been advised of the possibility of  such  damage.
Posting
For leased line, if your router supports CBWFQ, you can setup classes for your 3 groups.  This would work well for outbound traffic, but inbound (unless you manage the far side's egress) is very, very difficult to effectively manage.
policy-map egressSample
class office
bandwidth percent 20
class lab
class wifi
bandwidth percent 10
You'll need class-maps to match traffic.
class-map match-all OFFICE
description *** Office Network ***
class-map match-all LAB
description *** Laboratory Network ***
class-map match-all WIFI
description *** Public Network***
policy-map EGRESS
class OFFICE
  bandwidth percent 40
class LAB
class WIFI
interface FastEthernet0/0
ip address 192.168.0.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
duplex auto
speed auto
interface Ethernet0/0/0
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
interface Serial0/1/0
ip address 212.115.130.140 255.255.255.0
clock rate 2000000
just confirmed the ISP Providers side they will be deploying the Lease Line via FE.
i was lookinf for a guide how would i apply the following policy map into each port. simulation done on packet tracert.
can you assist me further?
thank you
Disclaimer
Posting
Unknown exactly what your simulator will support, i.e. what I might suggest might not be accepted on it.  Also, even with real routers, features can vary, i.e. also again what I might suggest might not be accepted on your actual router.  Lastly, I'm not at a real router, at the moment, to verify syntax.  All that noted, something like:
ip access-list extended OFFICE
permit ip 192.168.0.1 0.0.0.255 any
match access-group OFFICE
(similar for other networks)
interface serial0/1/0 (or whatever interface you'll be using to isp)
service-policy output EGRESS
PS:
If hand-off will be FE, you'll like want a hierarchal policy.
e.g.
policy-map EGRESS_SHAPE
class class-default
service-policy EGRESS
shape average 5000000
(apply this policy to interface instead)
I'm aware that simulator vary on actual device especially with the IOS installed on it.
but with this. it will help me with the goal i want to attain. if i could make this work. all left with me to do access-list blocking like p2p and other bandwidth hog protocols.
the main concern is with the outbound traffic going to different locations.
will give feedback anytime once i got this working with a simulator. GNS3 would be a better option.
thank you for now.
Disclaimer
Posting
If your targeted IOS support HQF, I would also suggest adding fair-queue to each class queue.
If your IOS is pre-HQF, you policy might not be accepted with your bandwidth settings since the total beyond 75% (excluding default).  Either using smaller percentages (as I did earlier - ratios will still be preserved) or you'll need to change reserved bandwidth on interface.
for 1841 router. what IOS should be installed to support all your suggestions? im not familiar with IOS capability all i know enterprise has it all.
Disclaimer
Posting
Assuming its supported for the 1841, recall HQF is 12.4(20)T or later; any feature set.
Hello Joseph,
current version of the 1841 router im using is
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(17b)
PS:
e.g.
class class-default
I wasn't able to apply the highlighted part...
current config as follows:
i got this error
Router(config-cmap)#match access-group OFFICE
% Invalid input detected at '^' marker.
current config:
  description ** Office Network **
class-map match-all LABORATORY
  description ** Laboratory Network **
  description ** Public Network **
policy-map EGRESS
class OFFICE
  shape average 2000000
class LABORATORY
class WIFI
  shape average 1000000
description *** LAN to OFFICE ***
speed 100
full-duplex
description *** LAN to LABORATORY ***
speed 100
full-duplex
interface Serial0/0/0
description *** WAN to ISP ***
clock rate 2000000
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 212.115.130.13
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip access-list extended LABORATORY
permit ip 192.168.1.0 0.0.0.255 any
permit ip 192.168.0.0 0.0.0.255 any
ip access-list extended WIFI
permit ip 192.168.2.0 0.0.0.255 any
I lack 1FE port on actual device
Disclaimer
Posting
Try:
match access-group name OFFICE
You should be able to apply policy to your serial.
Unless you have a really need to restrict outbound usage per class, remove the child class shapers.  The CBWFQ policy will insure each class gets its minimum proportion of bandwidth, but they can use more if its available (i.e. not being used by your other classes).
PS:
Since your simulator is pre-HQF, I would just shape for your aggregate.  This will enable WFQ for all flows.
Try:
i was missing a syntax.
All need to restrict is Download bandwidth from WAN to LAN(either OFFICE/LAB/WIFI), while Upload bandwidth will be maximized by OFFICE only(if possible to config this)
will i remove the shaping from the config?
PS:
how would i "shape for aggregate?"
QOS really confused me alot....
current config:
match access-group name LABORATORY
match access-group name WIFI
policy-map EGRESS
class OFFICE
class LABORATORY
class WIFI
class class-default
speed 100
full-duplex
speed 100
full-duplex
clock rate 2000000
ip http server
Disclaimer
Posting
Download is difficult to correctly restrict.  For upload, you need the shaper if working with less than full interface bandwidth.
class class-default
Posting
Do the Current config will work?
to what interface will I put the EGRESS_SHAPE?
policy-map EGRESS
class OFFICE
class LABORATORY
class WIFI
class class-default
speed 100
full-duplex
speed 100
full-duplex
clock rate 2000000
ip http server
Thank you
Disclaimer
Posting
It should, although I suggest this as better:
policy-map EGRESS
class OFFICE
class LABORATORY
class WIFI
class class-default
interface x
service-policy output EGRESS_SHAPE
Your WAN interface.
Matt Ehrhart
You want CBWFQ for outbound traffic (shaping) and policing for inbound traffic.  Policing is described in further detail:
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t2/feature/guide/ftpoli.html#wp1019755
