HELP: Cisco 2900 Configuration
AhmedQa
i need to help me for configuration because am now work as a technical network in my company. and this is my first task.
i have a cisco router and need to configure the Static IP with below details:
IP: 37.224.119.XX/31
Getway: 37.224.119.XX/31
IP Domain name: saudi.sa
DNS: 84.235.6.xx
DNS: 84.235.57.xxx
please anyone can help me to configure the above IP in router
Seb Rupik
Hi there,
It would be good to know which interface you are connecting to your gateway device, but on the assumption you are using a routed switchport, the config will look like:
int gi0/0
 ip address 37.224.119.XX 255.255.255.254
 no shut
ip domain-name saudi.sa
ip name-server 84.235.6.xx 84.235.57.xxx
ip route 0.0.0.0 0.0.0.0 37.224.119.XX
cheers,
Seb.
thank you for replay.
the LAN IP should i configured on gi0/1 as following
int gi0/1
 no shut
int gi0/0
 no shut
ip route 0.0.0.0 0.0.0.0 37.224.119.XX < did you mean here put the getway ?
AhmedQa
when am try to add IP
NWEPUBLIC(config)#int g
NWEPUBLIC(config)#int gi
NWEPUBLIC(config)#int gigabitEthernet 0/0
NWEPUBLIC(config-if)#ip add
NWEPUBLIC(config-if)#ip address 37.224.119.XX 255.255.255.254
% Warning: use /31 mask on non point-to-point interface cautiously
