Help !!! Cisco RV042 EU and Switch SG300-20 Compatible?
Ralph Rankin
Hi Everyone,
I'm newbie in Cisco device thats why i have confussion in my layout network design if this device working properly if i put this to my netwok.
i want to config my router with 3 different subnet and in switch area i want to create 3 vlans with different subnet on each. may question is, is this posible for this kind of router to route my vlan network?
here is the IP address i want to add in IP Table.
Gateway
192.168.2.1/24
192.168.8.0/24
192.168.9.0/24
192.168.10.0/24
in Switch
VLAN1
192.168.8.100/24
VLAN2
192.168.9.100/24
VALN3
192.168.10.100/24
thank you,
Raf
Nataliya Omelyanyuk
Hi, Raf
Based on your router data sheet (http://www.cisco.com/en/US/partner/prod/collateral/routers/ps9923/ps9925/data_sheet_c78-501225.html  ), you can't route between VLANs on it - as it does not support this feature. So you can create only 2 routing interfaces (marked as WAN interfaces on router panel) and apply IP addressing to it. LAN ports support port-based VLANs - that means that you can isolate traffic flowing over these interfaces, but it will belong to the same IP subnet still.
Your switch supports up to 32 IP interfaces ( http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps10898/data_sheet_c78-610061.html ) and you can apply to it configuration you suppose to do.
BR,
Nataliya.
paolo bevilacqua
Wrong forum - tty "small business, routers, switches"
