Help configuring 2 871 routers
patchmty1
I'm trying to configure 2 871 routers but can't get the vlan ports to send anything out the Wan port.
The Wan Ports are conected to a 2Mbps Metro-wan link that connects 2 sites and the switch ports are connected to our local lan.
Attached is the output from sh run
Thank you for any help
purohit_810
Level 5
Level 5
We are not able to read your attachmnt
Please attach fil againa and let know.
- Dharmesh
just use other editor than notepad, which can handle both windows and unix style CR/LF.
nikolay-shopik
First of all your access-list 100 permit ip any any in end so you better remove other strings before it's just wasting of router cpu cycles.
Vlan interface
ip address 192.10.10.207 255.255.255.0
default-router 192.10.10.244
from dhcp pool are not same machines behind router will try to send packets to 192.10.10.244 not 192.10.10.244 as suppose to be.
