LINK REDUNDANCY TO SERVERS
cfajardo1_2
EXISTING SETUP
2 6500
2 3750 stacked in each floors
uplinks from both core switch to each floor forms link redundandancy using stp and hsrp
QUESTION:
1. what will i do now to have link redundancy to servers which are to be direcTly connected to the core? WHAT IS THEBEST PRACTICE?
tHANKS A LOT
Jon Marshall
Are you 6500's connected to each other via a layer 2 trunk ?
If so server redundancy can be achieved by dual honing your servers to both 6500 switches use active/standby NIC configuration on your servers.
Jon
Jon Marshall
Jon
