Help!!!Configuring a Router especialy cisco1700series
paulgrg22
Hello..
Any body here who wants to share their expertise in router configuration and installation?Can you give me the step by step procedure on how to do router configuration and installation..thank
paul
guruprasadr
Level 7
Level 7
HI Paul,
Pls refer the Link below for Basic Feature-by-Feature Configuration Document:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/826/swg/routconf.htm#wp1015102
Pls Rate if HELPS
Best Regards,
Guru Prasad R
Amit Singh
Paul,
Please find the link below for hardware installtion and configuration guide for Cisco1700 series router.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/1700/1721/index.htm
HTH,
-amit singh
a.shaukat
what is thatyou want to know exactly...
All i want to know is how to set-up a router how to configure it how to connect it to LAN how to connect it to MODEM and switch all the command that i need to know..anyhelp??thanks
