HELP configuring Cellular0 on a Cisco881G
arjun.n
Hi Team,
I have a Cisco 881G with PCEX-HSPA-3G card for which I have successfully configured for internet.
As the above one has come to end of life, we got the replacement 881G with embedded 3G modem.
I can't get Cellular 0 to use ppp encapsulation:
Router(config-if)#encapsulation ppp
Cellular0: Only SLIP encapsulation supported
Router(config-if)#
This is on a Cisco 881G, the IOS is below
Router#sh ver | in bin
System image file is "flash:c880data-universalk9-mz.151-4.M4.bin"
Router#
Router#
Could you please help me if you found any solution??
Thank You
Arjun
9 Replies 9
Tagir Temirgaliyev
sorry
not see that the issue of a new version
try another ios
Sandeep Choudhary
Hi Arjun,
For Cisco 880 series, we need to use IOS 12.4(22)YB1 or above to fully utilize HSPA support.
if you need more info then please check this page:
http://inetpro.org/wiki/Initial_configuration_of_a_881G_router_Cellular_interface
Hi Sandeep,
Thanks a lot for the reply.
I currently have the C881G+7-K9 with embedded modem where we do not need any express card and just need to insert the SIM card in a slot available behing the router.
So this IOS holds good for this as well?
Arjun
Hi Arjun,
I think this IOS should work.
Please try with this IOS first , if not works then upgrade with new one.
If you have some confusion then please visit this page:
Everyting is step by step:
http://www.davidsudjiman.info/2009/05/29/cisco-881g-and-pcex-3g-hspa-configuration-cheat-sheet/
Please mark answered this question,if you are satisfied with this info.
Sandeep
Hi Sandeep,
I have seen the link and they are for the old type of 881G routers.
The one I have are with embedded modem.
Arjun
Hi Arjun,
Please check this, may be it helps.
http://www.cisco.com/en/US/docs/routers/access/1800/1861/software/feature/guide/mrwls_evdo.html#wp1496202
SUMMARY STEPS
1. configure terminal
2. interface cellular unit
3. encapsulation ppp
4. ppp chap password 0
5. asynchronous mode interactive
6. ip address negotiated
Dont forget to mark answered this question, if you are satisfied.
Nope, when I enter the "encapsulation ppp" under cellular interface, I get the error message shown in my 1st post.
Can someone help in getting the updated IOS for c880data-universalk9-mz.151-4.M4.bin
Arjun
try to download newest or early ios.
when working with 15th ios the errors are common
Tried that but there is no data for the current IOS I am using.
When try to put the IOS in the Cisco Navigator, it gives an error telling there is no version.
Any help
Thank you
Arjun
