Help configuring t1 bridge
burlingtoniowa
Hi there,
I wish to create an ethernet bridge between different network segments on the same subnet over t1.
I am replacing two adtran ta850's with two cisco 2801, each router has wic-1dsu-t1-v2 installed, to communicate over a telco t1 from Qwest.
We need to do this because of an application that uses multicast udp is communicating over the network and requires 100mbps full duplex... the adtrans are gen 1 and only give 10/half and the application vendor thinks this is a problem.
I have made a T1 crossover cable to connect the two serial ports. it is about 1 meter long.
On unit "pd 2801" with ip 192.168.11.66 AL is lit, CD is not lit.
On unit "ds 2801" with ip 192.168.11.67 AL is lit, CD is lit.
I defaulted both routers and entered configuration by hand based on examples I found on the net.
The routers cannot ping each other.
Here is show ver, show diag, and show run on both units.
Can someone please suggest revision to my configuration? Thanks!!!!
-----------------------------------------------------------------------------------------------------------   information on pd2801
pd2801#show ver
Cisco IOS Software, 2801 Software (C2801-IPBASE-M), Version 12.3(11)T5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Sat 02-Apr-05 21:22 by yiyan
ROM: System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
pd2801 uptime is 23 minutes
System image file is "flash:c2801-ipbase-mz.123-11.T5.bin"
Cisco 2801 (revision 5.0) with 114688K/16384K bytes of memory.
Processor board ID FTX0922Y19T
2 FastEthernet interfaces
1 Serial interface
WIC T1-DSU
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62592K bytes of ATA CompactFlash (Read/Write)
pd2801#show diag
Slot 0:
        C2801 2FE 4SLOT Mainboard Port adapter, 3 ports
        Port adapter is analyzed
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        Chassis MAC Address      : 0013.c46e.3c2e
        MAC Address block size   : 34
        PCB Serial Number        : FOC09172MUM
        Hardware Revision        : 5.0
        Part Number              : 73-8190-05
        Board Revision           : A0
        Top Assy. Part Number    : 800-23435-02
        Deviation Number         : 0
        Fab Version              : 04
        CLEI Code                : IPM7G00CRB
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : CISCO2801
        Version Identifier       : V01
        Processor type           : 86
        Chassis Serial Number    : FTX0922Y19T
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C3 06 00 13 C4 6E 3C 2E 43 00 22 C1 8B 46
          0x10: 4F 43 30 39 31 37 32 4D 55 4D 40 04 1C 41 05 00
          0x20: 82 49 1F FE 05 42 41 30 C0 46 03 20 00 5B 8B 02
          0x30: 88 00 00 00 00 02 04 C6 8A 49 50 4D 37 47 30 30
          0x40: 43 52 42 03 00 81 00 00 00 00 04 00 CB 89 43 49
          0x50: 53 43 4F 32 38 30 31 89 56 30 31 20 D9 02 C1 40
          0x60: 09 86 C2 8B 46 54 58 30 39 32 32 59 31 39 54 FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x100: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x110: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x120: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x130: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x140: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x150: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x160: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x170: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x180: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x190: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1B0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC/VIC/HWIC Slot 3:
        FT1 PMC4351
        Hardware Revision        : 1.2
        PCB Serial Number        : FOC0938065E
        Part Number              : 73-8346-05
        Board Revision           : A0
        RMA History              : 00
        Deviation Number         : 0-0
        Product (FRU) Number     : WIC-1DSU-T1-V2
        Top Assy. Part Number    : 800-22193-03
        CLEI Code                : IPUIAPRRAA
          0x00: 04 FF 40 00 52 41 01 02 C1 8B 46 4F 43 30 39 33
          0x10: 38 30 36 35 45 82 49 20 9A 05 42 41 30 03 00 81
          0x20: 00 00 00 00 04 00 80 00 00 00 00 CB 94 57 49 43
          0x30: 2D 31 44 53 55 2D 54 31 2D 56 32 20 20 20 20 20
          0x40: 20 C0 46 03 20 00 56 B1 03 C6 8A 49 50 55 49 41
          0x50: 50 52 52 41 41 FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
pd2801#show run
Building configuration...
Current configuration : 980 bytes
version 12.3
hostname pd2801
boot-start-marker
boot-end-marker
mmi polling-interval 60
mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
no ip cef
no ftp-server write-enable
bridge irb
interface FastEthernet0/0
description connected to pd 2960
no ip address
duplex auto
speed auto
bridge-group 1
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/3/0
description t1 circuit to ds
no ip address
no fair-queue
service-module t1 clock source internal
service-module t1 timeslots 1-24
bridge-group 1
interface BVI1
description ip address for management
ip address 192.168.11.66 255.255.255.0
ip classless
ip http server
snmp-server manager
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
line aux 0
line vty 0 4
login
end
-----------------------------------------------------------------------------------------------------------   information on ds2801
ds2801#show ver
Cisco IOS Software, 2801 Software (C2801-IPBASEK9-M), Version 12.4(18b), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Mon 19-May-08 16:27 by prod_rel_team
ds2801 uptime is 24 minutes
System image file is "flash:c2801-ipbasek9-mz.124-18b.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Processor board ID FTX0922W1CV
1 Serial interface
WIC T1-DSU
ds2801#show diag
Slot 0:
        Port adapter insertion time 00:24:53 ago
        Chassis MAC Address      : 0014.1c14.2c00
        PCB Serial Number        : FOC09180YLV
        Board Revision           : A0
        Fab Version              : 04
        RMA History              : 00
        Processor type           : 86
        Chassis Serial Number    : FTX0922W1CV
          0x00: 04 FF C3 06 00 14 1C 14 2C 00 43 00 22 C1 8B 46
          0x10: 4F 43 30 39 31 38 30 59 4C 56 40 04 1C 41 05 00
          0x60: 09 86 C2 8B 46 54 58 30 39 32 32 57 31 43 56 FF
        FT1 PMC4351
        PCB Serial Number        : FOC112972GC
        Board Revision           : A0
        RMA History              : 00
          0x00: 04 FF 40 00 52 41 01 02 C1 8B 46 4F 43 31 31 32
          0x10: 39 37 32 47 43 82 49 20 9A 05 42 41 30 03 00 81
ds2801#show run
Current configuration : 903 bytes
version 12.4
hostname ds2801
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
bridge irb
description connected to ds 2960
no ip address
duplex auto
speed auto
bridge-group 1
no ip address
shutdown
duplex auto
speed auto
description t1 to pd
no ip address
no fair-queue
bridge-group 1
interface BVI1
ip address 192.168.11.67 255.255.255.0
ip forward-protocol nd
ip http server
no ip http secure-server
control-plane
bridge 1 route ip
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
https://supportforums.cisco.com/thread/2028581
check this thread out. It does what you are attempting.
5 Replies 5
vmiller
Level 7
Level 7
one of the clock sources should be line. Heres a decent write up.
http://www.beauwallace.com/blog-posts/51-guide-back-to-back-t1-wic-serial-link-on-cisco-routers
Ah... this helped...
Now I have CD on both T1 cards. Unfortunately they are still both in alarm.
Just to be sure, I made another t1 crossover cable.
Looks like my original t1 crossover cable was bad!
With the new t1 cable, serial 0/3/0 comes up on both units.
I am able to ping each unit from the other unit.
Test your homemade cables!!! And, I do appreciate the tip about line versus internal clocking, this was also an important key to resolving this issue.
Thanks a lot, vmiller!!!!
You are most welcome. Good luck with the bridging over a T-1,
don't expect miracles.
