Help Configuring Unequal Load Balance
ziaullakhan
Hello Everyone
Can some one help me configuring unequal load balance in a single 3800 series router. I have 2 wan connections from a single ISP. One is via fiber (8MB) and the other is via Wireless (2MB). I want to utilized both the wan links; like 70% of traffic should go via fiber link and 30% of traffic should go via warless. And at the same time the wireless should work as a backup link. Can some one please help me configuring this…….
BR
Zia Khan
5 Replies 5
spremkumar
Level 9
Level 9
Hi Zia
Are you using these links for internet connectivity or for accessing any applications via the links ???
regds
Dear Kumar,
Both the links are for internet access only.
Giuseppe Larosa
Hello Zia,
if on the sides of both links there is a single ISP the only way I know would be to use EIGRP protocol with variance 4 command.
But it is difficult an ISP will give the EIGRP option unless it is providing connectivity over an MPLS cloud and you are using an MPLS L3 VPN service.
If the ISP is providing you internet access and EIGRP is not an option I think you can only define the wireless link as the backup of the primary link.
Hope to help
Giuseppe
Dear Giuseppe,
My ISP doesn't have any MPLS cloud and they neither using any MPLS L3 VPN service. I want to solve this issue since its been long time now. please help cant I used any policy or some other thing to achieve unequal load balance.
BR
Zia Khan
Zia,
If all traffic is originating in your LAN or in other words if you know the source of traffic then i would suggest you:
1. split your network in 2 subnets....1 being a major (subnet 1) and another minor (Subnet 2)...
2. define ACLs for both subnets
3. configure a route-map....like this
route-map loadbalance permit 10
match ip address subnet1
set ip next-hop serial
set ip next-hop wireless
route-map loadbalance permit 20
match ip address subnet2
then on router internal interface apply this route-map with ip policy loadbalance command
now major chunk of traffic should be routed to serial as primary and to wireless if serial goes down.
Hope it will help
Chetan !
