Help Flashing IOS to 2821 Router
Hi All,
i just got a used Cisco 2821 router from Ebay. I have 1GB of memory in it and a 512 Flash card in it. The unit has no OS on it. Well it has a
rommon 1 >
Prompt.
How do I update it to the newest IOS? It doesn't have commands I am used to, like CD or tftp. I tried to use the TFTPDNLD, but it didn't work. I don't know what to do to get the IOS on it and up and running, can anyone help?
Thanks!
Mitch
P.S. There is no show command so I can't do a show run.
Only Commands are:
rommon 4 > ?
alias               set and display aliases command
boot                boot up an external process
break               set/show/clear the breakpoint
confreg             configuration register utility
cont                continue executing a downloaded image
context             display the context of a loaded image
cookie              display contents of motherboard cookie PROM in hex
dev                 list the device table
dir                 list files in file system
dis                 disassemble instruction stream
dnld                serial download a program module
frame               print out a selected stack frame
help                monitor builtin command help
history             monitor command history
iomemset            set IO memory percent
meminfo             main memory information
repeat              repeat a monitor command
reset               system reset
rommon-pref         Select ROMMON
set                 display the monitor variables
showmon             display currently selected ROM monitor
stack               produce a stack trace
sync                write monitor environment to NVRAM
sysret              print out info from last system return
tftpdnld            tftp image download
unalias             unset an alias
unset               unset a monitor variable
xmodem              x/ymodem image download
O
Leo Laohoo
You can copy the IOS from your TFTP server to the CF flash directly using a multi-card reader.
Make sure the CF is formated with FAT16.
Can you give me steps on how to do that? I found a site that tells me how to transfer the image from a TFTP server, but once it is over, it doesn't seem to show up or boot up with it.
Do you have a multi-card reader which you can connect to your PC or laptop via USB?
I do, but it looks like I got it. For osme reason the first tftpdnld didn't work, but I tried a different bin and it worked, so I am all good, thanks!
