help for 7206 XVR router
lgoocisco
Hi all,
I got a used 7206 router, but without any IOS inside, nothing on bootflash(4M), nothing on Flash(20M), how do upload the boot image and IOS ?
any input appreciated.
autobot130
Break out the console cable and copy xmodem the smallest basic IOS image to the bootflash:
http://cisco.com/en/US/products/sw/iosswrel/ps1831/products_command_reference_chapter09186a00800d9835.html
Or if you happen to have another Cisco device that uses flash cards. ie: 6500 - download tftp image for the 7200. insert the flash and copy the image over and then remove it and insert in the 7200. then in boot loader: "boot slot0:
thanks for your important reply.
currently, I have an IOS file on the Flash card(Slot0), but no image on the bootflash, so I only can get rommon1> prompt, here is the command I do have,
rommon 5 > ?
alias set and display aliases command
boot boot up an external process
break set/show/clear the breakpoint
confreg configuration register utility
cont continue executing a downloaded image
context display the context of a loaded image
cpu_card_type display CPU card type
dev list the device table
dir list files in file system
dis disassemble instruction stream
frame print out a selected stack frame
help monitor builtin command help
history monitor command history
meminfo main memory information
repeat repeat a monitor command
reset system reset
set show all monitor variables
show_spd show all SPD data
stack produce a stack trace
sync write monitor environment to NVRAM
sysret print out info from last system return
unalias unset an alias
unset unset a monitor variable
I tried "boot slot0:xxxxxxxxxxx.bin", but no luck.
thanks
