Help for C3825 system crash!!
justlaicvtc
Here's the 3825 log sesstion
please help me for find problem!
after crash , i have upgrade the rommon
because the old rommon cannot read flash in rommon mode
but when i upgrade the rommon to the newest version
it was also can not read flash
and i upgrade the ios 12.4(9T) to 15.1(M5) it was no any problem
but two days later it was continuous reboot
and cannot load the ios, please help me thanks a lot!
A Board  僠療
**僠€
*** Emulating mis-aligned store at 0xff
*** Emulating mis-aligned store at 0xfffffcfc
    PC = 0xbfd83f50 ... failed, opcode = 0xc
ROM Monitor Can Not Recover From Exception
A Board
*** Emulating mis-aligned store at 0x001ffffd
    PC = 0xbfc03f54 ... failed, opcode = 0x5
A B
*** Machine Check Exception ***
  PC = 0xbfd82e68, SP = 0x800002b0, RA = 0xbfd82e70
  Cause Reg = 0x00008060, Status Reg = 0x30400002
A Board
System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 2005 by cisco Systems, Inc.
System Bootstrap, Version 12.4(13r)T15, RELEASE SOFTWARE (fc1)
Copyright (c) 2010 by cisco Systems, Inc.
*** Watch Dog Timeout Reset ***
ra = 0xb5bfffff, EPC = 0xffffffdf
*** BCM 1125 went through a full reset. HT/PCI fabric reset. ***
*** Bus Error (Load) Exception ***
Access address = 0x0
  PC = 0x9fd816a0, SP = 0x8000cf40, RA = 0x9fd89a94
  Cause Reg = 0x0000041c, Status Reg = 0x30408003
A Board
*** TLB (Store) Exception ***
*** Emulating mis-aligned store at 0x00000002om Exception 瞬貙
    PC = 0xbfd83f4c ... failed, opcode = 0x37
A Board
*** TL
ra = 0x41000, EPC = 0xffffffff
    PC = 0xbfd83f50 ... failed, 瞬
Access address = 0x4848
ra = 0xbfff7ffa, EPC = 0xffffffdf
Total memory size = 512 MB - DIMM0 = 0 MB, DIMM1 = 512 MB
c3825 platform with 524288 Kbytes of main memory
Main memory is configured to 0/72(dimm 0/1) bit mode with ECC enabled
Upgrade ROMMON initialized
*** E艛貙貙貙貙貙貙 貙貙貙貙貙
擬 瞬
ra = 0xb73ffbde, EPC = 0xffffffdf
A Board
*** Emulating mis-aligned load at 0x00841000
    PC = 0x00841000 ... 鸆僯纚
0 Replies 0
