Help getting DMZ access from outside
metuckness
I have an ASA5510 that I have been training myself on to get more experience with CISCO IOS and I am having an issue routing traffic from outside to the DMZ (which is actually just a second network, I haven't actually created a DMZ yet).
So I have an interface called Outside, Inside, DMZ, VOIP.
I can muddle my way through to allowing certain traffic from the Outside to the Inside, but for some reason I cannot grant traffic from the Outside to the interface I have labeled as DMZ.
I was hoping someone could take a look at my config and tell me what I have wrong in regards to allowing traffic from the Outside interface to access resources on the DMZ interface like I can allow to the Inside interface. I am going to work on restricting access for the DMZ, but right now it is at level 100 just like the inside. Eventually I want to move all the accessed things to the DMZ and configure it properly, but right now just trying to learn the other stuff.
I want to enable and allow WWW and SSH (on a different port) to a device on the DMZ at 128.162.1.25
: Saved
ASA Version 9.1(4)
hostname ASA5510
domain-name
enable password liqhNWIOSfzvir2g encrypted
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
passwd liqhNWIOSfzvir2g encrypted
names
dns-guard
interface Ethernet0/0
 description LAN Interface
 nameif Inside
 security-level 100
 ip address 10.10.1.1 255.255.255.252
interface Ethernet0/1
 description WAN Interface
 nameif Outside
 security-level 0
 ip address 255.255.255.128
interface Ethernet0/2
 description DMZ
 nameif DMZ
 security-level 100
 ip address 10.10.0.1 255.255.255.252
interface Ethernet0/3
 description VOIP
 nameif VOIP
 security-level 100
 ip address 10.10.2.1 255.255.255.252
interface Management0/0
 management-only
 shutdown
 nameif management
 security-level 0
 no ip address
boot system disk0:/asa914-k8.bin
ftp mode passive
clock timezone MST -7
clock summer-time MDT recurring
dns domain-lookup Inside
dns domain-lookup Outside
dns server-group DefaultDNS
 name-server 8.8.8.8
 name-server 8.8.4.4
 name-server
 name-server
 domain-name
same-security-traffic permit inter-interface
object network ROUTER-2811
 host 10.10.1.2
object network ROUTER-2821
 host 10.10.0.2
object network DNS-SERVER
 host 192.168.1.2
object network ROUTER-3745
 host 10.10.2.2
object network RDP-DC1
 host 192.168.1.2
object network BLUE
 host 192.168.1.6
 description Blue Iris Server
object network RBPI-SSH
 host 192.168.1.15
 description Raspberry Pi
object network RBPI-WWW
 host 192.168.1.15
 description Raspberry Pi Web Server
object network RBPI-VPN
 host 192.168.1.15
 description OPENVPN
object network RBPI-FTP
 host 192.168.1.15
 description Raspberry PI FTP
object network RBPI-DNS
 host 192.168.1.15
object network RBPI-DNS-TCP
 host 192.168.1.15
object network DVR
 host 128.162.1.25
 description DVR WWW
object network DVR-SSH
 host 128.162.1.25
 description Zoneminder DVR SSH
object network DMZ_outside
 subnet 0.0.0.0 0.0.0.0
object-group network PAT-SOURCE
 network-object 10.10.1.0 255.255.255.252
 network-object 10.10.0.0 255.255.255.252
 network-object 10.10.2.0 255.255.255.252
 network-object 192.168.0.0 255.255.255.0
 network-object 172.16.10.0 255.255.255.0
 network-object 172.16.20.0 255.255.255.0
 network-object 128.162.1.0 255.255.255.0
 network-object 128.162.10.0 255.255.255.0
 network-object 128.162.20.0 255.255.255.0
 network-object 192.168.1.0 255.255.255.0
 network-object 192.168.10.0 255.255.255.0
 network-object 192.168.20.0 255.255.255.0
 network-object 172.16.1.0 255.255.255.0
 network-object 162.128.1.0 255.255.255.0
 network-object 162.128.10.0 255.255.255.0
 network-object 162.128.20.0 255.255.255.0
 network-object 142.16.1.0 255.255.255.0
 network-object 142.16.10.0 255.255.255.0
 network-object 142.16.20.0 255.255.255.0
object-group network DM_INLINE_NETWORK_2
 network-object host
object-group network Outside_access_in
object-group protocol DM_INLINE_PROTOCOL_1
 protocol-object gre
object-group network DM_INLINE_NETWORK_3
 network-object host
object-group network DMZ_access_in
access-list USERS standard permit 10.10.1.0 255.255.255.0
access-list Outside_access_in extended permit tcp host ip object ROUTER-2811 eq
access-list Outside_access_in extended permit tcp host ip object ROUTER-2821 eq
access-list Outside_access_in extended permit tcp host ip object RDP-DC1 eq
access-list Outside_access_in extended permit tcp host ip object ROUTER-3745 eq
access-list Outside_access_in extended permit tcp any object BLUE eq
access-list Outside_access_in extended permit tcp host ip any eq
access-list Outside_access_in extended permit tcp host ip object RBPI-SSH eq
access-list Outside_access_in extended permit tcp any object RBPI-WWW eq
access-list Outside_access_in extended permit tcp any object RBPI-VPN eq
access-list Outside_access_in extended permit tcp host ip object RBPI-FTP eq
access-list Outside_access_in extended permit udp any object RBPI-DNS eq
access-list Outside_access_in extended permit tcp any object RBPI-DNS-TCP eq
access-list dmz-access-vlan1 extended permit ip 128.162.1.0 255.255.255.0 any
access-list dmz-access remark Permit all traffic to DC1
access-list dmz-access remark Permit only DNS traffic to DNS server
access-list dmz-access extended permit udp 128.162.1.0 255.255.255.0 host 192.168.1.2 eq domain
access-list dmz-access remark Permit ICMP to all devices in DC
access-list dmz-access extended permit icmp 128.162.1.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list DMZ_access_in extended permit tcp any host 128.162.1.25 eq ssh
pager lines 24
logging enable
logging asdm informational
mtu Inside 1500
mtu Outside 1500
mtu DMZ 1500
mtu VOIP 1500
mtu management 1500
icmp unreachable rate-limit 1 burst-size 1
icmp deny any Outside
asdm image disk0:/asdm-715.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
 nat (Inside,Outside) static interface service tcp
 nat (DMZ,Outside) static interface service tcp
 nat (VOIP,Outside) static interface service tcp
 nat (Inside,Outside) static interface service tcp port
object network BLUE
 nat (Inside,Outside) static interface service udp
 nat (DMZ,Outside) dynamic interface
nat (any,Outside) after-auto source dynamic any interface
route Outside 0.0.0.0 0.0.0.0 68.233.151.1 1
route DMZ 128.162.1.0 255.255.255.0 10.10.0.2 1
route DMZ 128.162.10.0 255.255.255.0 10.10.0.2 1
route DMZ 128.162.20.0 255.255.255.0 10.10.0.2 1
route VOIP 142.16.1.0 255.255.255.0 10.10.2.2 1
route VOIP 142.16.10.0 255.255.255.0 10.10.2.2 1
route VOIP 142.16.20.0 255.255.255.0 10.10.2.2 1
route Inside 172.16.10.0 255.255.255.0 10.10.1.2 1
route Inside 172.16.20.0 255.255.255.0 10.10.1.2 1
route Inside 192.168.1.0 255.255.255.0 10.10.1.2 1
route Inside 192.168.10.0 255.255.255.0 10.10.1.2 1
route Inside 192.168.20.0 255.255.255.0 10.10.1.2 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
no user-identity enable
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http 0.0.0.0 0.0.0.0 Inside
snmp-server community *****
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 Inside
ssh ip 255.255.255.255 Outside
ssh timeout 60
ssh version 2
ssh key-exchange group dh-group1-sha1
console timeout 0
threat-detection basic-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
ntp server 24.56.178.140 source Outside prefer
username encrypted privilege 15
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_1
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect pptp
  inspect icmp
  inspect icmp error
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
password encryption aes
hpm topN enable
Cryptochecksum:271c8513ae692ccc7c17a18977a6892f
: end
Luke Oxley
metuckness,
Thanks for your post. Just for your information, Cisco IOS and Cisco ASA are two different sets of code. IOS is the system that sits on top of Cisco routers and switches whereas ASA sits on top of Cisco's security appliances.
Moving on, whilst I can see you've made a great start at writing the configuration, I have spotted a few issues. Starting off with the basics, you've created your access control lists but not actually applied them anywhere. In ASA, unless the access control list is applied to an interface or applied globally, it takes no effect at all. You should first look to apply your access control lists with the following command syntax to their respective interface.
access-group Outside_access_in in interface outside
access-group <define-acl-name> <define-direction-in/out> interface <define-interface-name>
I cannot see any major issues with NAT'ing between the DMZ and Outside interfaces at the moment, so lets just start with this for now. Make the amendments and let me know how you get along.
Kind regards,
Luke
Please rate helpful posts and mark correct answers.
Oh, thanks for that clarification on the difference of platform terminologies, didn't realize that.
I guess applying the Access Group Outside_access_in to an interface would actually help :) some of those actually take place.
So I added that statement, I will see how it impacts as soon as I can. Right now I am at home so I can't access anything from an external IP. But I will be able to test the existing connections tomorrow (like if I can access the www site and ssh into switches remotely.
I did have this statement, but I don't think it was applied to anything:
I guess I had not put that statement in. I just checked the config and it didn't have it (I must of deleted my old one and forgot to add the new one) so I just added it and they are back up and working!
So I guess I just had not had that ACL applied to an interface or I deleted part of it since they used to work and forgot, but my outside access to the Inside network is working properly again, so thanks!
Do you have any pointers how I can grant outside access to the DMZ? Since that still seems to allude me. Because I want to bring my outside resources over to the zone, and lock it down properly instead of treating it as another inside interface. Since right now all it has is security cameras.
metuckness
Disregard.
