Rate Limit on 3650
BashedRoot
Level 2
Level 2
I have a few dedicated server clients that use excessive amount of bandwidth, even on 100mbit port speed. I'd like to find a middle ground to keep things stable. Can someone please explain in simple, command to command terms how to set a rate limit on a VLAN port, say for example 50Mbps or 25Mbps? I'd appreciate it. Thank you.
6 Replies 6
e.ciollaro
Level 4
Level 4
The document is over my head. I was hoping for a simplified way to just apply something in between 10-100Mbps speed like 25 or 50.
I made this configuration on a 3560:
ip access-list extended MyServer
permit ip host 10.10.10.10 any
class-map match-all MyServer-CMAP
match access-group name MyServer
policy-map PoliceServer-PMAP
class MyServer-CMAP
police 25000000 8000 exceed-action drop
class class-default
interface FastEthernet0/1
service-policy input PoliceServer-PMAP
On the 3560 i can't police on the vlan interface maybe the the 3650 can, try it out, and let us know if it works.
consider also shaping; I  usually prefer to shape because it's more "smooth" in regulating the bandwidth. The config is the same rasmus give you just use
  • shape average target _bit_rate
or
  • shape average interf_BW_percent
instead of police
Bye,
enrico
Yes I found that here http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/3e/qos/configuration_guide/b_qos_3e_3650_cg/b_qos_3se_3650_cg_chapter_011.html#task_6C85007887484ED29B900A3F7A20592B
But, I want to apply it per interface not globally on the switch. How do I apply the policy to specific interfaces (ports)?
I think that 3650 allow to configure the service-policy under an interf:
Switch# configure terminal
Switch(config)# interface gigabitEthernet...
Switch(config-if)# service-policy output <policy-map>
